Zanussi progress 1200 WASHER DRYER
PuT WASH ON AND HALF WAY THROUGH CYCLE AN E20 OR E10 ERROR MESSAGE COMES UP. TRY RESTART BUT NOTHING HAPPENS.
  • Anonymous Jun 30, 2008
    i have cleaned all filters i have swaped over pumps i have cleaned all pipes and still got E20 only on drying
This means that the filter is clogged. Get a towel (or two) in our case, and then unscrew the filter. It'll be full of lint.
Posted on Mar 19, 2008
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Too many E20 errors!
the first thing i would try is the pump..........if its not draining all the water out it will take longer to finish...........pump could be blocked......alst the hose from the pump........check both first.....
cheers
Aug 03, 2017 | Zanussi ZWD1680W Front Load Washer / Dryer
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
E20 message
The filter is blocked. Disconnect your power source. Open the panel. Have a towel or wet vac handy and a screw driver. There is a silver ring circling the drainage hose with a small screw on top. Loosen the screw. Pinch the hose on top and let water drain to wet vac or towel. Completely remove the hose from it's housing. Reach your thumb and index finger inside that same hose and pull out the filter. It looks like a small plastic cup with holes in it. Clean it out, wash it. Use your fingers or dry vac hose and feel the bottom of the inside of the hose where the plastic cup came from. Remove any debri that excaped past the filter with fingers or suction with hose til you can feel with your fingers that the bottom of the inside of the hose is clear. return the cup back inside the hose. Put the silver ring over the lip of the hose then place the hose back on it's metal housing which is attached to the machine. Make sure the hole is secured around the entire metal (if not you will get leakage). Tighten the small screw, pull down at the hose making sure it will not come off with the pressure of the water. Clean up any leakage. Close panel and I promise you, your problem will be solved. Good luck, from Cheryl AlAlexander
Dec 02, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
912 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
