Starting from the start, make sure the valve behind the fridge is open. then make sure when you disconnect the tube from the intake of the refrigerator, that water comes out. Then check the intake filter on the fridge for debris. Then defrost the freezer in case the intake line froze. If you still have no water going into the ice maker, the valve is probably bad. If you post the make/model and go through those steps I'll help you take the Icemaker apart...
I have a side by side Ultra Whirlpool model ED25RFXFB01 that has stopped dispensing ice....I do not...
(More)
I have a side by side Ultra Whirlpool model ED25RFXFB01 that has stopped dispensing ice....I do not hear the motor or anything moving. The water dispenses just fine and the light is also dispensing fine. The ice maker is filling up with no problem...just no dispensing of ice through chute...it's clear too.
frost built up in freezer and its to cold. The doors seals are tight and I have the setting turned...
(More)
frost built up in freezer and its to cold. The doors seals are tight and I have the setting turned to the warmest setting
i get ice build up around the top of the ice chute and the bottom of the ice bin, this is the only...
(More)
i get ice build up around the top of the ice chute and the bottom of the ice bin, this is the only place where ice will builds up over a period of a couple weeks. What could be causing this problem
