Question about Casio Exilim EX-Z57 Digital Camera
Dial stuck Our camera was dropped and ever since, it will take pictures however, the dial on the back does not let you select left to right - only up and down. This makes it impossible to review pictures and manually delete. Any suggestions?
    Problem Solver:
  • 4 Answers
Or try a DRY toothbrush, it's finer than a needle. This maybe a stupid question, but are you using a memory card?
Posted on Apr 04, 2008
  • 871 Answers
I suggest that you pry it slowly however be very careful as your dial may crack. just use a needle.
Posted on Jan 14, 2008
How do I set the dials on husqvarna viking 6000 sewing machine
The "dial" in the back is for decorative stitches which require a "programmer" to be inserted with the stitch formation you want to form. For a straight stitch no cam is required in the back of the machine. The three dials on the front:
Upper Left: Stitch selector
Upper Right: Stitch lenght
Lower: Stitch width
Using the upper left dial select the straight stitch picture
Using the upper right, choose your stitch lenght
Using the lower, choose your needle position, left/center/right
Dec 13, 2014 | Husqvarna Sewing Machines
My camera when it turns on says ' Mode Dial Is not in the proper posistion ' I haven't dropped or anything! Will my warrinty cover it!?
Hi jayderehbein,
Make sure that the dial for selecting either video capture or image capture is not stuck somewhere in the middle , therefore a good idea would be try moving it to different positions and then back to the usual image mode and this message would go away ...
Hope this helps ..:) Your feed back would be appreciated.
Jun 19, 2011 | Nikon S8100 Digital Camera
Where is the self timer on the c-3000 digital camera
try to check this path: Press the Menu button, then press the top/bottom arrows on the Jog dial to select DRIVE. Press the right arrow and press the top/bottom arrows to select. Press the left arrow on the Jog dial to confirm the setting. If you take a
picture without pressing the OK button, the setting will be valid until the Menu is canceled. To take a picture using the selftimer, when the shutter is released, the Selftimer/Remote control signal lights for
approx. 10 seconds then blinks for approx. 2 seconds before the picture is taken. To stop the activated selftimer, press the Menu button.
Sep 06, 2010 | Olympus C-3000 Zoom Digital Camera
How to set date and time on the picture
Press power button, select mode dial to Auto, press Func button, use up/down arrows to select L and then use left/right arrows to select the icon which has a small clock in the lower right corner.
Jul 16, 2010 | Canon PowerShot SD890 IS / IXUS 970 IS...
Mode dial on my Kodak DX6490 camera is hard to turn!
dissmantle the back case (watch for 1 hidden screw under rubber covers), lift plate on back of lcd screen, remove screw on back of dial, clean where it sits on both sides (most probably from a liquid spill...tea, coffee...) , apply some lube with a cottonbud ore a bit of tisue and rebuild.
hope this helps
stewart
Apr 04, 2009 | Kodak EasyShare DX6490 Digital Camera
Zoom dial stuck
Sounds like damaged zoom buttons.
Mar 20, 2009 | Casio Exilim EX-Z57 Digital Camera
I have a panasonic DMC-TZ3 when I turn it on it displays mode dial is not in proper positon. It will let me take pictures in certian modes but will not let me view pictures or be on the heart mode ro scn1....
I assume you have tried rotating the dial back and forth to try to clean the contacts when camera is off.
If this hasn't worked, try dropping some contact cleaner, available from radioshack or try alcohol first, with a toothpick under the edge of the dial when camera is on its back, at the same time rotating the dial back and forth. I haven't tried it, but the dial knob may pull off the camera if you can get a little pry under it.
If this doesn't work, consider getting a quote from a local camera shop, cause pana with be too expensive. Also, repairmen and those upgrading to the TZ5 sell very good TZ3's on ebay, and will buy yours the way it is. The difference you would pay for a sell and buy ebay will likely be less than a repair bill by a camera shop.
Jan 16, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Dial won't turn to delicate or handwash...
Is it brand new?? if it is the factory did not align the knob (dial assy) properly with the main computer, and on top of that all the cycles you think you are selecting really isnt that cycle at all!! It is two back from full left or right whichever way is not fully extending. It is quite frustrating for me to get it back right when i replace the main computer! The first one or two took me a while to get it right again. PLEASE rate my solution as solved if you feel I answered your question accurately. Thank you
Oct 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
COBRA DC5500
You can download the manual from the link below: http://cobradigital.com/manuals/1/DC5500.pdf Looks like you put the camera in capture mode (slider switch in the center) then press the left arrow key on the dial to select flash mode. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Cobra Digital DC5500 Digital Camera
Casio Exilim EX-Z57 Digital Camera Logo
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
