Single entry of operating system
I made a mistake installing my xp operating system. i made it 3 times but only one is running. how could i remove the other 2 that is not working.
  • 265 Answers
What makes you think that you have three operating systems on your machine? Are you offered three different versions when your computer boots? Did you install to different HDD's or partitions / folders?
Posted on Dec 26, 2007
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
Assassins creed 3 in _except_handler4_common not found
Have Install Assassin Creed 3 Run Erorr This Produce Entry Point Except Handler_4 Could Not Be Located Dinamic Linc LibRary Msvcrt.dll
TeLL Sell Number
03124455996
Dec 02, 2012 | Microsoft Windows XP Professional
I am trying to get rid of the xp home security 2011 virus.
Manual Removal:
1. Press Ctrl+Alt+Del on keyboard to stop process associated to "XP Home Security 2011?. When Windows Task Manager opens, go to Processes Tab and find and end the following process:
(random characters).exe
2. You need to update your installed antivirus application to have the latest database.
3. Thoroughly scan the computer and any detected threats must be removed. If removal is prohibited, it is best to quarantine the infected item. Manually locating and deleting of malicious files should also be performed. Please see files below that are related to XP Home Security 2011 Virus.
4. Registry entries created by XP Home Security 2011 must also be remove from the Windows system. Please refer below for entries associated to the rogue program. [how to edit registry]
5. Exit registry editor.
6. Get rid of XP Home Security 2011 start-up entry by going to Start > Run, type msconfig on the "Open" dialog box. A windows containing System Configuration Utility will be launched. Go to Startup tab and uncheck the following Start-up item(s):
7. Click Apply and restart the computer.
XP Home Security 2011 Removal Tool:
In order to completely remove the threat from a computer, it is best to download and run Malwarebytes Anti-Malware. Sometimes, Trojans will block the downloading and installation of MBAM. If this happens, download it from a clean computer and rename the executable file before executing on the infected computer.
Using Portable SuperAntiSpyware:
To thoroughly clean a computer, it is best to do a separate scan of another security program so that other infected files not detected by anti-virus application can be remove as well. Download and run SuperAntiSpyware Portable Scanner.
Apr 06, 2011 | Computers & Internet
I installed Windows XP a second time on my hard drive hence I now have a menu on boot up where I select which operating system I wish to use. I have since delted the second install of XP but the menu...
If you just formatted the partition with the second XP installation on there, it should remove the boot menu where you choose which installation to go to.
Here are a few options for you to choose from.
  • Option One: Open Start-Run and enter msconfig Click the tab "BOOT.INI" The contents of the boot.ini file are shown and a number of configuration settings are available. Under Operating systems, delete the one you don't want. Be careful not to delete the wrong one.
  • Option Two: Right-click on "My Computer" and choose "Properties" from the context menu. The System Properties dialog box will open. In the section "Startup and Recovery" click the button "Settings". To delete the unwanted operating system from the boot display menu, use the "Edit" button on the right of the entry.
  • Option Three: If the OS is Windows XP Professional, it has a command line utility for manipulating boot.ini called bootcfg.exe.
    Click start, type CMD, click OK and you are presented with the command prompt. Type bootcfg /? It will list the description and parameter list. Once again, you can delete the unwanted OS.
  • Option Four: Boot to the XP install disk and open up the command prompt utility of the disk. Enter "fixmbr" and press enter. Restart the computer and remove the disk.
Mar 05, 2011 | Microsoft Windows XP Home Edition English...
I have microsoft windows xp professional. i have promble to remove unwantd program by add / remove
Uninstalling/ removing a software can be a little difficult sometimes, but NOT impossible.
CCleaner is a small size and very useful utility for system maintenance. I have been using it for years and no problems at all.
So, first download CCleaner from the following link and install it and follow these steps.
http://www.filehippo.com/download_ccleaner
1. Open CCleaner
2. Click Tools, Select the software you want to uninstall, click it
3. Click Run uninstaller
Otherwise, go to 'program file' and manually delete the unwanted program and run CCleaner to remove its registry entries (Scan for issues).
Let me know if any further assistance is required
CreativeTECH
Jan 03, 2011 | Microsoft Windows XP Professional
Hi there, I recently had to reinstall Windows XP and of course then reinstall the Airplus DWL-G510 drivers. I accidentally did this whilst the card was still installed in the PC (Which it tells you not to...
If you are not OK with editing the XP registry, then I would enlist a computer savy friend to help you. If you make a mistake the computer will be inoperative and needs Windows XP re-installed again.
The other way is to re-install Windows XP from scratch but make sure the Airplus is card removed first.
To fix your problem using Regedit follow these steps :-
1. Remove the program using Add/Remove Program.
2. Delete the Airplus folder from the Program Files folder.
3. Click on Start - Run and type Regedit (registery editor)
4. Click on Edit then Find and type Airplus
5. Click Find Next
6. When Regedit finds a Airplus entry then delete this entry and press the F3 key to find the next Airplus entry - delete and repeat until all Airplus entries have been removed.
7. Close Regedit and reboot the laptop.
8. Install the Airplus driver etc.
If this doesn't work then re-install Windows XP from scratch, it might be quicker to solve this problem in the long run.
Have fun.
Let me know how things go.
Nov 15, 2009 | Computers & Internet
I am trying to install my hp psc 1610 printer on my computer, but there is no entry for this printer. Is there another on that is compatible
No entry? I assume you mean No windows driver was listed. In that case, try going to the HP site and downloading the driver, then install the driver, then look in the list for an entry. A driver teaches a computer how to operate a device. If theres no entry for that device listed, then the computer does not know what it is.
Aug 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
Xp not installed
boot into xp...from the RUN command type msconfig...select the BOOT tab. Remove any statements that point to Vista being on the C:\....Also, make sure the the entries for XP point to the right location.
-SuperDale
May 12, 2009 | Computers & Internet
While playing the sims2 game for a few minutes, my monitor shuts down, but my pc keeps running.
remove the game , run regedit, find sims2 delete entries like data , values and after re install the game. chk for virus
May 25, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
74 people viewed this question
Alun Cox
David Payne
David Payne
