Question about Nokia N72 Cellular Phone
Bluetooth handsfree connectivity
I Have two phones N72 and nokia 7500.Both have same bluetooth client v 2.0.My bluetooth handsfree works perfectly alright with 7500 but iam not able to use it with my n72.please tell me the step by step instructions how to connect it.
  • dipak_1987 May 17, 2009
    bluetooth problem
    Problem Solver:
  • 18 Answers
Bluetooth handsfree profiles are needed by N 72 which is missing by default in N 72 you will have to install bluetooth profiles. Please refer to nokia website for details on how to install bluetooth profiles
Posted on Mar 08, 2008
How to connect bluetooth headset to my nokia c5-03 phone
Hi Madhav,
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  • The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
  • Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
  • When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
  • Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
  • If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
  • That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 19, 2011 | Motorola Mobility Bluetooth Headset, Mini...
I have a nokia n72 and it is not connecting with nokia bh-104 what must i do
hello,please kindly follow the instructions below, 1.put on the bluetooth headset and as well the nokia N72 phones bluetooth
2.then use the nokia N72 to search the bluetooth,if found you would be asked to enter a passkey,then enter 0000 or 1111 there your headset and nokia N72 has been paired,there you can start to make good use of your device.
3.if your nokia does not pair the headset,then follow the steps below. MENU>SETTINGS>PHONE SETTINGS>CONNECTIONS>BLUETOOTH>OPTIONS>SHOW AVAILABLE TO ALL>CLICK YES AND SAVE. you are better after that to enjoy your device.
take care.
Jul 31, 2011 | Nokia N72 Cellular Phone
I tried my best. bt i couldnt connect my nokia n73 with bluetooth handsfree...plz provide me solution for to connect...
in most nokia N series, you will have your handsfree device paired to your cellphone. it also depends on your handsfree model. some bluetooth handsfree models are not compatible with nokia N series. Jabra handsfree models are compatible with nokia phones. best buy.
Nov 01, 2010 | Cell Phones
I have bluetooth hed set but not connected to nokia n72
swith on the bluetooth on both phone and on headset.... paior bothdevices........
Oct 18, 2010 | Nokia N72 Cellular Phone
N72 can be connected to your PC in two ways.
1. By USB cable
2.Via Bluetooth.
Bluetooth means you need to buy a device called Bluetooth dongle to provide bluetooth connectivity to your system.
For both usb and bluetooth, you need a software called Nokia PC Suite to access the mobile contents and for data transfer
Aug 03, 2010 | Nokia N72 Cellular Phone
My nokia 7610 says unable to perform bluetooth operation
When you get an error "unable to perform Bluetooth operation", it means that one of the Bluetooth devices is not communicating correctly. It could be your phone, or it could be the Bluetooth device that you are trying to connect to. And that will depend on the device that you're connecting.
There's a possibility that the Bluetooth requirement of your device is not supported by your Nokia phone. Example, you are trying to pair up a Bluetooth handsfree car kit. "IF" the phone does not support the handsfree profile, then you will get this error message.
So, you need to make sure that your device and your phone is compatible with each other. Second, try to pair up the phone into different Bluetooth devices, like phones, headset, etc. Doing this will let you know if the Bluetooth on your phone is working or not. If it works with another Bluetooth devices, then the problem has something to do with the device that you are trying to connect to.
Thank you and good luck!
Jul 31, 2010 | Nokia 7610
Didnt connect bluetooth headset to N73
Sometimes what happens is that we keep looking for BT devices without making them visible. Is it so in your case too? Go to settings of the headset and make it visible and your mobile visible to the headset. then you must pair them and also authorize them to connect without pass code etc. Then they will work.
Aug 02, 2009 | Nokia N73 Cellular Phone
How to connect nokia 70 with motorola handsfree
is it motorola handsfree headset??
if so...
activate bluetoth of ur nokia cell,
activate the handsfree (pressing long the on off button,for connecting with new device)
1, it automaticaly send the connection request to nokia cell
2 if not, go to paired devices of ur nokia cell blutooth and search more devices.
select motorola handsfree,
enter passcode 0000
it will work.
May 01, 2009 | Motorola Mobility Bluetooth Hands-Free...
N72 - Not able to Connect Motorola Bluetooth Headset ( H500)
My cellphone Nokia N72 is not paring with Nokia -BH-102.
When i began to search , but it not connecting
By Vijeesh
Jun 24, 2008 | Nokia N72 Cellular Phone
Nokia N72 Cellular Phone Logo
294 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
