Question about Philips DVP642 DVD Player
Problem in philips dvd
When we insert vcd disc dvd working properly but when we insert dvd disc showing no disc.
  • joylily Apr 06, 2008
    We've had this DVD player for less than 3 years. Tonight it stopped in the middle of a movie. I tried everything to get it to play and finally turned it off. When I turned it back on, it kept trying to load and then I got a "no disc" message. I tried again and it did the same thing and then tried another DVD. Nothing is working. I am going to get a cleaning disc and hopefully that will work. If not, it would seem to me that the most logical thing to do would be get a new one since repairing it would cost more than I paid for it.
  • naldfuentes May 22, 2008
    when we insert vcd disc dvd working properly but when we insert dvd disc showing no disc. i also tried to use a dvd cleaner but nothing happens.
Dvp 642 player - there is no output from surround sockets
Posted on Jul 08, 2008
IT WILL SHOW NO DISC IF THE DVD IS HIGH DEFINITION AS THIS PLAYER IS NOT HD CAPABLE.
Posted on Mar 16, 2008
Philips DVP Playing problem
try to clean or change the laser
Mar 11, 2010 | Philips DVP642 DVD Player
My phillips 5.1 dvd player not playing dvd disc, only playing vcd
the laser lens on the optical pickup is dirty or scratched. to clean: buy a disk cleaner and use it per instructions. if it doesn't help, you can do it manually. remove the top, remove the top off of the disk assembly (you may have to remove the whole assembly first) until you see the lens. be careful with the cables and wires. use a lint-free swab (not a q-tip and not your finger), gently wipe off the lens. replace the covers and test. if it still doesn't work, it may be scratched or damaged. in which case, it needs to be replaced.
Jul 30, 2009 | Philips DVP642 DVD Player
My dvd palyer shows NO DISC for any disc i want to play.
the laser is probably no good or the tiny motor that spins the disc is no good.there is a clamper assembly that goes in the hole in the disc.turn it and see if it spins freely.there is a bronze bushing on the top of the motor driving it ,and a small drop of light oil on the bearing will make it work again if it is gummed up..if the motor does not get the disc speed from 250 to 600rpm,fast,the laser does generate the proper info and the computer says error.yes the motors can be replaced,but the cost is as much as a new one
Jul 03, 2009 | Philips DVP642 DVD Player
It was working fine when i bought it,but now whatever dvd or vcd i insert it is showing "disc error".. please help ,,i dunno what to do!
Hi this is abhishek and welcome to fixya,,,,,,,,,
it normally caused by lens getting dirt,,,,first clean the lens with soft cloth then try inserting disc i think the problem will be solved....
thank u.......
May 03, 2009 | LG DVP7772 Portable DVD Player with Screen
DVD player plays VCD/SVCD but not DVD
there is a problem with the disc motor, replace it
Apr 08, 2009 | Philips DVP642 DVD Player
Player unable to load discs when inserted
http://forum.videohelp.com/topic350059.html
I think I found these adjustments! There are two tiny surface-mount potentiometers (could be capacitors also) sitting in the small circuit on laser assembly.
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
Nov 09, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD PLAYER 3166 SHOWING NO DISC
I AM HAVING A DVD PLAYER 3166 . MY DVD PLAYS CD /VCD/MP3/JPEG AND USB. BUT WHEN I INSERT A DVD VIDEO IT SHOWS NO DISC ERROR. BUT CD IT ACCPTING.KINDLY HELP ME OTHER WISE TELL ME WHERE SHALL I GET IT REPAIRED . PLEASE GIVE ME THE PHONE NOS OF PHILIPS CUSTOMER CARE THANKS, G.SEKARAN, CHENNAI
Aug 26, 2008 | Televison & Video
DVD/CD RAM Devices
try some 3rd party software, nero, magiciso, poweriso,,,to burn discs,,,
Or
try using XP service pack 3..
good luck.
Feb 23, 2008 | Dell (0Y435) Internal 24x CD-ROM Drive
LG DVP7772 Portable DVD Player with Screen showing disc error
its aged and old, all pordable dvd players stuff up eventually, get a new one.
Jun 14, 2007 | LG DVP7772 Portable DVD Player with Screen
"no disc" message
sounds like you have a problem with the laser.laser has to focus a lot sharper to play dvd thus will play vcd but not dvd.Try cleaning first and if this doesnt work would suspect laser faulty,.
May 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Philips DVP642 DVD Player Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
