Question about Dell C600 (002UH) Motherboard
Dell 6000 motherboard
Shorted motherboard the adaptor will cut off immediately
  • 95 Answers
Don't understand the question. Please post a little more detail. Does the computer operate at all? Is it an adaptor problem as in no power. Could be a power connector problem? Give more detail.
Posted on Dec 27, 2007
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Ac adaptor is internittently charging my inspiron 6000 laptop
Time to buy a new. If under warranty you might be able to get a new one for free. They can be cheap on the web. Just google part number. Avoid the company, they usually charge more.
Jul 30, 2009 | Dell Inspiron 6000 Notebook
My inspiron 6000's power flickers on and off intermittently, switching between A/C & battery power. I've replaced the power cord. Any other ideas?
The issue seems weither with DC in cable (cable from adaptor jack to motherboard) or with the adaptor so please try with any other adaptor.
Jul 06, 2009 | Dell Inspiron 6000 Notebook
I have a dell inspiron 6000 when i cut it on, it stays on for like 10 seconds then it powers off i open it up and didn't see a problem with it
Any LEDs flash or come on when you power on the system (Scroll, Caps and Numlock LEDs to be exact)?
ALso, if you remove the battery, HDD< optical drive , Wireless card, Modem and Memory, does anything change? If no change, the motherboard will need to be replaced.
Jun 12, 2009 | Dell Inspiron 6000 Notebook
Laptop will not charge from working adaptor
You may have damaged the dc connector on the motherboard. If the battery is not charging either then take the laptop to a repair shop and have them check the dc connector.
Jun 08, 2009 | Dell Inspiron 6000 Notebook
Hp pavilion 4000, will not recharge battery, i have a new battery, my electiricl cord is good, will not power with electrical,
If the battery is a known good one and the ac adaptor is a known good one that you have used before, then it has to be the motherboard that is faulty.
Make sure your using a good power outlet to hook the ac adaptor to just to be sure.
May 10, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 power adapter problem
If the DC socket at the back of the laptop is moving, that means that one or more soldering joints on the motherboards are broken. The way to fix the problem is by disassembling the laptop completely, the laptop, taking motherboard out, and replacing the socket.
This requires full disassembling and a precision de-soldering and soldering job on the motherboard.
Using the computer in this conditions can cause further damage.
Apr 21, 2009 | Dell Inspiron 6000 Notebook
Wont power up
the vr\ery first thing what u have to do is that disconnect the ac adaptor and take the battery out of the computer and then press and hold down the power button without the battery and the adaptor for one minute and then connect the ac adaptor and put the battery back in and then try and turn it on and what u can do is that try and turn on the computer only with the battery and then take the battery out and try and turn it on only with the adaptor,and then what u can try is that try with the different adaptor having same configuration,and try and connect the ac adaptor into the different wall outlet....good luck
Jan 28, 2009 | Dell Inspiron 6000 Notebook
Labtop not charging
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 6000 Notebook
Dell C600 (002UH) Motherboard Logo
52 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
