The squealing noise coming from your dryer is caused by the front glides located on the top bearing, they act like a pad against the drum and when gone, will make an awful squealing. part number for the 4 glides that may be needed is WE3X87 this is a common problem as it is a wearable part. if you don`t replace these in time it will grind all the way through your top bearing and start to deteriorate your drum. if its been like this for a while you may also need a GE drum bearing they come in short and long sizes. and are relatively cheap to replace.hope this helps
Thanks
Was this helpful?
Yes
No
Popular Solutions for GE DBSR453EBWW / DBSR453EBCC
The upper plastic trim piece that goes around the drum inside the door (drum bearing?) on my on my...
(More)
The upper plastic trim piece that goes around the drum inside the door (drum bearing?) on my on my GE DBSR453EB2WW dryer is broken. How do I begin to disassemble the sides/top to get at this? Where do I start?
GE dryer DBSR453EB2WW Timer doesn't work. Dryer functions , but timer doesn't shut-down as should if...
(More)
GE dryer DBSR453EB2WW Timer doesn't work. Dryer functions , but timer doesn't shut-down as should if set at dial. Removed timer , applied power and observed plastic gear move slowly. What else can I try?
The knob seems striped will not turn and pliers will not turn it. The dryer was running perfect...
(More)
The knob seems striped will not turn and pliers will not turn it. The dryer was running perfect until yesterday. It is a G.E. But I cannot find a model # this is just a guess.
