Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
AMANA SOLUTION LIMIT 3 WIRE
I am trying to find a solution limit 3 wire for a Amana HTM. Can you help me?
  • 80 Answers
Amana ALE643RBW...Wire to the high limit thermal fuse melted and broke into...what gauge of wire do I use to replace it?
Use the same size or the next size up. Assuming you solved the problem as to why it melted in the first place.
Jan 28, 2018 | Amana Dryers
DLE330RAW amana dryer running too hot
The control thermostat on the blower housing is the one you need to change if it is getting too hot. It is taking too long to shut off the element. The only other thing it could be is a blocked vent making it overheat. The fuse is set for 350f the limit on the element is a 250 f one. I suspect the 250 f limit on the element is doing the drying not the control stat. Hence you getting overheat but not hot enough to blow the fuse.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 13, 2013 | Amana DLE330RAW Electric Dryer
Replaced the thermostat and high limit regulator on my amana comercial dryer lea60aw but forgot to tag wires, starting from the thermostat on the blower, i'm not sure where the wires go to, i have
if i were there i could tell you.just think about it .the wires have to make a path all the way through the element.it should have a wiring diagram in the control panel that will help you trace the path.hope this helps.
Dec 04, 2017 | Amana Dryers
My Amana electric dryer, Model # NED4500VQ0 is not heating clothes enough to dry a load in one cycle. I changed the thermostat already. The back glows orange and is heating. I figure it has to be the...
Not sure about the hh limit or the element, but make absolute certain that there is good flow of air. Check to see if the vent is clogged. Remove the hose from the back of the dryer and see if air is flowing very hard. Use a vacuum cleaner or a wire or something if it is clogged. Similarly, check the hose itself. If the hose collapses when you attach a vacuum to it, it is clogged. Dryers require heat AND air flow to dry properly. :)
Mar 22, 2012 | Amana Dryers
I have an Amana PTAC unit model no. PTH153B50AM. It will not heat, but the fan runs continuously in the heat mode. The unit has a label that says it has a manual reset for the heater, but no direction as...
First unplug the unit......Take the front cover off, take the wire screen off where the front fan is there is 4 or 5 screws that hold the plate that was under the screen. The electric heating elements are under that plate between the evaporator coil and the front blower wheel. It will lift straight up and give you access to the elements. In the electric heating element area there is a limit switch with a red or black button in the center of it push it to reset the limit it is on the right hand side by the controls. I wish I could find a picture to show you but I couldn't find one. It is not easy to get to... Hope this helps.
Feb 12, 2011 | Amana PTH153B50AM Air Conditioner
1.Our gaz range (with electronic range control) Amana ACS3350AS oven bake works normally at 350 F for 40 minutes, then stops. While the broil can still work at this point, it's likely the Oven - High...
Works normally for 40 minutes? Then after she cool down will work again? Let me look un momento mon ami. Aha Your temp sensor might be faulty,
Another thang it could be is a weak ignitor,
An oven limit would shut down and NEVER come back to life. It ain't gonna be no limit er fuse.
Basic American oven fault codes and more HERE
Feb 11, 2011 | Amana ACS3350 Gas Kitchen Range
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
SQD26VW AMANA STOPS COOLING AT THE TOP,BOTTOM SEEMS TO BE COOLING AND WHEN PROBLE ACUURS THE WATER STOPS
Hi R,
Based on your description, the defrost limit has failed and should be replaced. The job takes about 30 minutes. The part you'll need is a WR50X55. You can find it online by plugging that number into a search engine, or pick one up locally at an appliance parts retailer.
UNPLUG THE FRIDGE BEFORE CONTINUING!!!
Clean out all the stuff in the freezer and remove the shelves. Then remove the panel in the back of the freezer section. You'll see the defrost limit clipped to the evaporator coils at the top right. Remember which tube it's clipped to, then take it off the tube.
Now clip the wires close to the limit and remove the limit. Strip those 2 wires back about 3/8" and connect them to the new limit one wire at a time. Cap these wires off with wire nuts. All you gotta do now is use one of the clips in the kit (I use the "U" shaped one, NOT the "W" shaped one) and clip it to the tube you removed the old one from. Rebuild everything and plug the fridge back in. That's it!
NOTE---> The fan inside the freezer will NOT come on immediately. The derfrost limit you just installed must get below 55 degrees first, then it'll turn the fan on. OK?
If there's anything else I can help you with, please write back. If not, and this has fixed your problem, please rate me.
SG
Apr 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Blower is running. Inducer motor comes on then shuts off after 10 seconds. Diagnostic lights say open limit switch. Any suggestions?
Yes, look for manual resettable limits on your exchangers (where the flame goes into), or just check for continuity with meter. There is also an auxilary limit on exhanger cabinent, take those two wires off and plug in a paper clip, restart furnace, if it works replace the limit. You can do the same with the manual reset one, paper clip the two wires and bypass the limit. Don't leave this bypassed for long, it protects your furnace from fire hazard, replace asap.
Dec 06, 2008 | Amana Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
26 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
