Question about Sony PlayStation 2 (PS2) Console
Not playing all games
Ps2 is only playing +3yrs games only. all other games are diplaying "disc read error" please advise if possible????
  • Neil Floyd Dec 26, 2007
    all brand new games brought from major shops from security sealed packaging
    President:
  • 1,944 Answers
Are the games original or backups?
Posted on Dec 26, 2007
Why does error advise containing required content come up when playing watchdog ?
Sounds like a bad disc, or an error (bad sector) in the hard disc drive. You should try another copy of the game (try renting or borrowing one) and see if it works. If not look at the drive.
May 27, 2014 | Microsoft Xbox 360 Console
It reads the disc and when i play it crashes, sometime it does not read it.
Single Disc
The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
  1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
  2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
  3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  4. Check for specific game issues. Some games may have known issues or game play elements that appear as problems.
  5. Ensure the game is being loaded properly. With the power turned off on the system, replace the Game Disc (label side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
  6. Look for obvious physical damage to the disc. Remove the Game Disc and check the non-labeled side for cracks, scratches, smudges, or dirt. The Nintendo GameCube has extensive error correction capabilities and minor scratches or contamination should not cause issues in most cases. However, it is important to determine if disc damage is causing the problem.
    • If the disc is cracked
      Review our disc replacement policy to determine how to get your game replaced.
    • If it's dirty, scratched, or shows no obvious damage
      1. You may try cleaning the disc again with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
      2. Make sure the game is dry, then re-insert it and see if the error occurs again.
      3. If the game had been working normally, shows signs of physical damage, and now displays errors or lockups in areas it previously didn't, the problem is likely to be the damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
      4. If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.)
  7. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance.
Feb 24, 2011 | Nintendo GameCube Console
I inserted my game and it said "the game disc
Single Disc
Feb 20, 2011 | Nintendo GameCube Console
I was playing Super Mario Sunshine and then the game just said disk could not be read out of nowhere when I got to just one little part of the game it said Disk Could Not Be Read but it was only one part...
Single Disc
Jan 08, 2011 | Nintendo GameCube Console
My PS3 can't only PS2 games!!! 80028F17
Not all PS3s are able to play PS2 games - they started removing that functionality when they came out with the 60GB model. So if you have a relatively new PS3 (A year old or so), that's likely the reason.
Aug 10, 2009 | Sony Playstation 3 (PS3) Console
Wii will not play any of my games discs
Made a video showing how I fixed this exact problem on a Wii.
Mar 20, 2009 | Nintendo Wii Console
During Game Play Of Grand Theft Auto Vice City
The Disk May Be Internally Damaged Or Externally Damaged, I Would Advise To Get A Disk Cleaning Machine. Or Inside The Console The Laser That Reads The Disk May Be Broken Best To Send It To A Game Shop Or Your Nearest Retailer.
Jun 29, 2008 | Sony PlayStation 2 (PS2) Console
Ejecting a dvd
It's a mechanical problem and the unit needs to be opened up and serviced by a repair shop.
Sep 22, 2007 | Audiovox VOD1023 Overhead LCD Monitor -...
Disc reading issue
I advise you to send it back to sony if it is under warranty and report a faulty blu ray drive.
Aug 18, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 (PS2) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
