Maytag MSD2732GR Side by Side Refrigerator
Problem for Maytag MSD2732GR Side by Side Refrigerator
The refrigerator side is not cooling but the
By amhooper on Oct 11, 2009
the refrigerator side is not cooling but the freezer is
Best Solution
posted on Oct 11, 2009
Very Helpful)
woodchuck789
Rank: Guru  Maytag Refrigerators  Expert
Rating: 91%, 583 votes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
or
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
Not Rated)
Sassy6
Rating: 88%, 111 votes
can you hear the evaporator fan motor running in the freezer section? this motor forces the cold air from the freezer into the food section to keep it cool.
Was this helpful?
Yes
No
Popular Solutions for Maytag MSD2732GR Side by Side
Questions and Unsolved Problems for Maytag MSD2732GR Side by Side
Do you recommend Maytag MSD2732GR Side by Side Refrigerator?
Answer
Answer
water hookup was disconnected for months. after connection water dispenser and ice maker not... (More)
Answer
water and ice side does not dispense. water pipe was broken and fixed now the dispensers are not... (More)
Answer
leaks water from both side of the refrigerator, but not necessarily at the same time. The drain pan... (More)
Answer
I am using a two year old maytag side by side refrigirator with the model# MZD2667HIS. After... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
