Question about Brother HL-2040 Laser Printer
Toner cartridge brother hl - 2030 how do i take out the cartridge to put a new one in
  • 38 Answers
Pl z visit following site for help
http://es.alatest.com/Printers/Brother+HL+2030/pro-reviews/
Posted on Dec 26, 2007
Brother hl-2030 - hi, is it possible to know how many pages a drum has printed?
Most laser printer do not have a page counter, because the toner cartridge may come in a couple of toner sizes and there is no way of accurately determine how much tone is used on each page as this can vary considerably.
If the printer gives a message that the toner is low, you can get several more prints by shaking the toner in a horizontal position and placing it back into the printer.
Dec 02, 2010 | Brother HL-2030 Laser Printer
The last time I purchsed a Brother toner cartridge, HL 2030, I was told that since the unit was no longer produced the number was now HL 2040. It worked fine.This time the same product,identified as such...
You may be thinking of the drum unit. All Brother laser printers have an imaging unit and a separate toner cartridge. You can usually expect to get about 4-5 toner cartridges on one drum unit. There is a release tab on the back of your DR-350. When separated your two toner cartridges should look identical. Be sure to only purchase Brother original or high quality refills. As a toner technician at a Cartridge World store I have seen machines ruined becuase customer have wanted to save and extra $10.
Oct 29, 2010 | Brother Office Equipment & Supplies
Toner cartridge wiil not come out? paper is jammed brother 2030
You need to open the front door and grab the toner/drum unit and pull as hard as you need to. once the assy. comes out you press the blue button on the left side and the toner cartridge will separate from the drum unit. install the new toner or remove the paper jam as required. call if you need more info. 805-520-3003 steven
Feb 13, 2010 | Brother HL-2030 Laser Printer
How do i add toner to my hl 2030 brother printer ?
You don't "add" toner, you have to replace the cartridge. You can see it by clicking on this link:
HL-2030 Toner
You can refer to the User Guide for instructions. here is a link to it:
HL-2000 Series User Guide
Replacing the toner is covered in Chapter 5.
Thanks for using Fixya.
Jan 09, 2010 | Brother HL-2030 Laser Printer
Brother HL-2030 continually prints test pages
disconnect the printer from your pc and clear out all print jobs... leave it on and let it sit for a day... if no test page prints then the problem is your pc... if it starts printing like crazy then reset it via page 54 of the user guide if it still prints like crazy with the network cable or usb cable disconnected then you need to call brothers tech support but more than likely it shouldn't do anything... if this is the case... the problem is your pc... or your server...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 20, 2009 | Brother HL-2040 Laser Printer
My Brother HL-2030 won't work; All LED lights are flashing
Use the software to diagnose the problem or check for a paper jam and ensure the drum and toner is OK.
Dec 11, 2009 | Brother HL-2030 Laser Printer
Paper light flashes red...
I found just doing this one simple thing sorted the problem.
First take off the front cover. Pull the tabs on the side. Pull out the big toner and cartridge. Do you see the blue tab on the top shaped like an arrow/triangle? Slide the tab from right to left - reinsert toner close door.
Hope it works for you
JPW
Aug 30, 2008 | Brother HL-2030 Laser Printer
Toner Light
Hi.
Its nearly what the last post states,
I have had brother help desk on the phone recently due to this problem. If you get a toner cartridge that has no numbers on it, ( brother orginal parts have huge numbers stamped on the case) then the cartridge needs resetting, this is done by simply pushing the white lever on left handside about 40 degrees forwards, its stiff so give it a proper hard shove. No srews etc to undo.
Hey presto your light will go out.
Cheers
JPW
Jun 09, 2008 | Brother HL-2030 Laser Printer
False detection of toner low
The only remedy you have now is to change the sensor , for this you have to refer to the product manual you can download it from
http://www.brother.ca/en/products/pdf/QSG/HL2030-QSUG.pdf
Good Luck
Dec 05, 2007 | Brother HL-2030 Laser Printer
Brother HL-2040 Laser Printer Logo
163 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
