Question about AOpen AK77-600n Motherboard
Booting up to windows or cdrom
My pc wont boot from hardive or cdrom but it reckonizes them just keeps saying reseting boot drive success turning gate seccess starting cmain failure goes to set root and says error 17
Please try to boot with window server 2003 Cd .If that boot from server then error is with the OS which you installed
Posted on Dec 29, 2007
How to install windows xp in lenovo G460
if you have the windows XP disc. put it inside the cdrom drive then restart the computer. keep on tapping the F12 key once the computer is restarting. you will be rprompted with boot options. select your CDrom drive as boot device then hit enter. your computer should boot now using the cdrom. XP installation should be running now.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 07, 2010 | Computers & Internet
Reset cmos and now it won't showhard driveand it
can u view the HDD in Boot sequence in BIOS boot seq...have u reset the BIOS/COMS using any tools...try reseting the BIOS boot seq to boot from HDD insted of floppy or CDROM...also check how many HDD is displayed in the BOOT seq...the machine normaly boots from HDD 0....
else try to boot from CDROM....and insert a BOOT CD/WinXP cd in the CDROM drive...
Dec 15, 2009 | HP (D7580-60003) Motherboard
How do you access the boot list on my compaq armada 1750
Tap the F8 Key as soon as the Laptop is powered on, keep tapping it till it brings you to Boot Choice Menu Options.. Options such as: Safe Mode, Safe Mode w/ Networking, Last Known Good Config..etc... are listed here..
Press and hold the F12 Key If You Need To Get To Boot Choices.. Such As Boot From CDrom, Boot From LAN, Boot From USB Device..
Nov 17, 2009 | Compaq Armada 1750 Notebook
Computer wont start up...
It means it cannot find it's operating system or windows to start. When a PC boots it checks for boot devices, usually the floppy, then cdrom, then hard drive, if there is a disk in the floppy or if your pc is set to boot from cdrom and there is a disc in it - it will say OS not found.
The second possible cause is something has happened to windows - either the hard drive has failed or windows has lost it's startup files. If the drive appears to be normal and chatters slightly on startup ( a light clicking noise) then possibly running the original windows install disc and reinstallin windows should fix the problem, on 98 or ME you can re-install, on 2000 or XP try the recover/repair option first.
Oct 26, 2009 | Computers & Internet
Very slow system boot up and report for Express Gate error code C800002
What the error is telling you is there is an error on trying to install Express Gate. and best to install on a USB drive. If you must install it on the hard drive. you will have to set to IDE not AHCI or RAID mode. ExpressGate has to be installed on the SATA hard disk is connected to the red SATA port. (Other color slot can not be used)
May 07, 2009 | Computers & Internet
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
Windows xp keeps failing
check the bios and see what the boot order is for the boot devices. Hard disk 0 should be listed after the cdrom drive. this problem you are having might occur if the hard drive is down the list in the boot order, and not checked as being a valid boot device.
Sep 26, 2008 | HP Pavilion dv6000z Notebook
Want to reinstall to factory settings
As the pc is booting press F2 or Del (dependant on bios) and enter bios set up.
Choose to make your cdrom as first boot device, save settings and exit bios.
Insert cd drive before the boot up starts and there will be a screen prompt to "press enter to boot from cd", press enter and then the cdrom will go to the next step, asking press 'R' to repair or press 'Enter' to format and install windows, choose repair if you have documents you need on your pc.
The system will then go through a full repair installation, when complete your system will be repaired and everything should be as before with nothing lost.
You may have a faulty hard drive so if you cannot get windows to repair it will tell you theres no drive found.
Sep 10, 2008 | Toshiba Satellite A105 Notebook
STARTUP ISSUE ON TOSHIBA 4015CDT
Your BIOS is probably not set to boot from a CD-ROM. Luckily I have the same laptop so if you press and hold the "c" key when it boots up and keep holding it until it beeps at you it will then boot from a cd. You could also press esc and go into the BIOS if you're adventurous.
Aug 27, 2008 | Computers & Internet
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
AOpen AK77-600n Motherboard Logo
242 people viewed this question
Top AOpen Computers & Internet Experts
Alun Cox
Jim Goldsmith
Jim Goldsmith
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
