Yahoo Messenger Logo
Posted on Oct 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I already tried a new accnt but still my messages disappear when i press enter to send
micky dee
Level 3:
  • Yahoo Master 3,015 Answers
  • Posted on Oct 15, 2009
micky dee
Yahoo Master
Level 3:
Answers
3015
Questions
0
Helped
1060623
Points
8762
You have a scripting problem. Its probably the support software on your computer required to run Messenger. ( not included in the Messenger download ) Check your IE browser settings first.
To enable scripting:
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
Restart IE
Still not working ? Update software
use the links on this page to help update software.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/notices/mstabuguqscripterror.html
After updating, check that you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
Anonymous
Level 2:
  • Expert 89 Answers
  • Posted on Oct 14, 2009
Anonymous
Expert
Level 2:
Answers
89
Questions
Helped
17262
Points
202
This error is most likely from yahoo. Their system has been acting up recently. Try using their messenger for the web instead. www.messenger.yahoo.com/web
3answers
How do I text with Samsung Gusto 3 flip phone.
Create and Send a Text Message - Samsung Gusto™
  1. From the main screen, press the left soft key to choose Message.
  2. Select New Message then press OK.
  3. Select TXT Message then press OK.
  4. Enter the desired 10-digit mobile number(s) or email address(s) then press OK.
  5. Enter the message.
  6. To add a graphic, animation or sound:
    • Press the right soft key to choose Options.
    • Select Add then press OK.
    • Select a category (Graphic/Animation/Sound) then press OK.
    • Select an item then press OK.
  7. Press OK to choose SEND....
  8. try this.
tip
How To Enter Unlock Code Into Motorola Mobile Phones Step By Step Instruction...
Model: All Motorola; check below for exception
1. Insert an unauthorized Sim Card and turn ON your phone
2. "Enter Subsidy Code" box appear
3. Enter Unlock Code
WARNING: If one of these messages appears:
- "Contact Service Provider"
- "Tamper Alter"
- "Wait before enter special Code"
- "Contact Service"
It's because you or somebody already enter too many wrong codes, you just have to let the phone ON at these errors message (do not close the phone if V3) and after 40 minutes to 12 hours, the message " Enter Subsidy Code" will appear again.
Model: A1000 and other A series model
1. Click on the Phone icon
2. Enter **057*
3. "Locking Enter Personalization" box appear
4. Enter Unlock Code
5. Press Ok
Model: L6i & L7i (NOT L6 and L7)
1. Press and hold * key and enter 787090
2. "Menu Network" box will appear
3. Select Yes
4. Press OK
5. Will ask for code
6. Enter Unlock Code
Model: All Motorola 3G network model
1. Enter **057*
2. Enter Unlock Code
Motorola CDMA & TDMA
1. Enter 74663# [Menu] [Menu] and you will be asked for a Subsidy Code
Unlock Motorola CLIQ (SIM Unlock) 1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Motorola MPX
2. If the phone is asking for NETWORK PIN
3. Enter the NETWORK PIN
4. If the phone is asking for SERVICE PROVIDER PIN
5. Enter the SERVICE PROVIDER PIN
6. Your phone is now unlocked
Network PUK
If the phone is asking for NETWORK PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see an Engineering Menu:
1. Select Options
2. Select GSM Test
3. Select Send AT command
4. Now you will see a new window Saying "Send AT Command"
5. Enter AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN]"
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. Turn your phone off, take battery out. Put battery back in. Power on the phone and leave it for 40 minutes to 12 hours until the message "Enter NETWORK PUK" is gone. Now enter the Unlock Code and 00000000 (eight zero's) as a new password
Service Provider PUK
If the phone is asking for SERVICE PROVIDER PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see a Engineering Menu: 1. Select Options
2. Select GSM Test
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. If you do not have the original Sim Card or if the original Sim Card is not accepted because you flashed the phone with other firmware, then we cannot help you
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
on Apr 07, 2011 • Cell Phones
Send picture messege
1. In Idle mode, press <Menu>2. Press <Add> on the Subject 3. Enter the message subject and 4. Press <Add> on the Picture 5. Add an image file. 6. Scroll to the Sound line and 7. Add a sound file. 8. Scroll to the Message line and 9. Enter the message text. 10. Press <Opt.> and select Done.
11. Press <Opt.> and select Send. 12. Select an empty location. 13. Enter a destination. 14. Press <Send> to send the message
Or you can use samsung x640 "code" in my blog
http://pcgadgetdeni.blogspot.com/2013/02/all-phone-samsung-codes.html
How can i send my message?
To send a message just do this:
If the person you want to message is already added to your YM, just double click on the contact name and a pop out screen will appear then type in automatically your message then press enter. That means it was sent already.
If the person is not listed on your contact 1.Click ACTIONS on the messenger menu 2.on the drop down menu under ACTIONS click SEND INSTANT MESSAGE 3.Click OTHER CONTACT and type inside the box the messenger ID of the person you want to send a message with then click OK 4.type in your message then click SEND or just press ENTER
Hope I solved your problem. Please don't forget to rate my answer. Welcome to Yahoo Messenger! :)
2helpful
2answers
How i send email
If you use Mail classic you will have "compose mail" to write your mails,
If you use All-new mail there will be a "new" button at the left hand side click on and start composing.
In all-new mail if your press the "n" button for a while on your key board it will directly take you to the composing mail page.
Once you are done you can press"s" button on key board to send the mails through.
Good luck ! if you think your problem solved don't forget to rate
Jan 03, 2011 • Yahoo Mail
I have a samsung sgh-c300 when I try to send a sms message my message disappears and a new screen appears with the meassage 'enter sms centre' my text messages are not sent. Please help
hi
there must be the message centers that not define in your mobile kindly check the message settings of your Mobile.kindly message center of your mobile. then ask your service for this problem .. they can fix it
thank you
2helpful
KYOCERA fs-1920 Has the message instal MK coming up? Dopes this mean order a maintenance kit?
It means the page count has triggered this message.
You _should_ get a maintenance kit.
But if you simply can't take the time/money, you'll find a new menu item in the menus after service. the new item is 'maintenance', get to there and press enter. (May need to press enter twice), the menu item, flashing light, and install MK message will all disappear.
1helpful
HOW DO I SEND A MESSAGE TO ALL MY FACE BOOK FRIENDS AT ONE TIME?
There are two ways to do this:
1) Write a note, and tag all your friends in it.
2) Go to your inbox, compose a message, and, by typing in the first letter of their first name and then pressing enter, enter all your friends into to "To:" field. (ie. press "a", enter and repeat these two until it stops adding, then "b", enter, etc.)
Another way to do this would be go to the groups app, create a new group, and then check all your friends (very fast) and invite them to join. Then just call your group "___ got a new cellphone" or something.
Password forgotten
assuming this is winxp then when u start up computer right at the boot screen keep pressing F8 until something pops up that says Safe mode and all these other stuff go on to the one tht says safe mode
and then u will seee a new screen name named Administrator if u get lucky then u can go on to administartor w/out a password and go into administrator ten control panel then remove the password for the other accnt te u forgot the password for and restrt nad logon to tht oter accnt
3answers
Yahoo messenger not working
Do u use yahoo messenger patch???Or try portable yahoo messenger...
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
