Question about Uniden MapTrax GPS352 GPS Receiver
Uniden gns8350 wont turn on
Hav a uniden gps gns8350 wont turn on tried to plug it in and turn it on but it switches off straight away and say battery is flat can you get replacement batteries?
  • 1 more comment
  • Dave Clarke Mar 26, 2008
    Have a Uniden Maptrax GPS352 that wont turn on. Any solutions?
  • joker_chen Mar 11, 2009
    my 8365 shows it has some software application problem. it doesn't work now. help me~.~
  • buck65413 May 11, 2010
    my uniden gns8360 gps wont boot up all other features work. any idears
Have you tried just leaving it on charge for a few minutes before trying to turn it on?
Posted on Jan 07, 2008
Make sure that the power lead in in the power out let and not the earphone outlet
Posted on Nov 27, 2008
    Problem Solver:
  • 3 Answers
Yes. Left it plugged in in the car. (There's no AC adapter for this unit and you are warned not to use anything but the adapter provided by Uniden).
Posted on Aug 19, 2008
My lms 332c wont stay on tried soft reset turn it on goes off what to do?
what do you have your unit hooked to too power up straight off the battery or thru a power switch if thru a switch hook it straight to bettery
Nov 15, 2012 | Lowrance Lms 522c 5" Screen Color Internal...
My tom tom wont turn on where is the reset bitton
look for a small hole on the outside case near the sd card reader. might need a paperclip or pin to poke the microswitch inside the hole. simply clicking the switch doesn't work, try holding it for 5 seconds then try to power up. Common problem with GPS devices, (my mio included) is after being plugged in for a long time, the battery life becomes nil and it relies upon the charger. Check tom to xl for further problem solving. google search TOM TOM XL won't power up.
Mar 14, 2010 | Tomtom XL 340S Car GPS Receiver
My garmin won't turn on. I have tried the plug in
it does have an internal battery, but that normally wont prevent it
from turning on unless the battery is defective.
plug it in to the usb cable on your computer for a while (normally it will start right up) then slide to power switch to the on position for about ten seconds.
if that fails, press and hold the lower right corner of the screen and then slide the power switch to the on position while holding the lower right corner of the screen and follow the directions once it starts
i can give you something else to try before you go and spend money on a battery...a battery should be the last thing to do, even though it will more often then not fix the problem thats tempory..
if it turns out you think you need a battery, i will point you to one with instructions on how to change it.
bill
Mar 12, 2010 | Garmin nuvi 265 Car GPS Receiver
Uniden trax 430 frozen
I have had a similiar problem with my Trax 430. The screen freezes at the system shut down stage. I have to plug it into the computer via the USB cable. It then recognizes the computer and attempts to do an USB update. Then just unplug it. It should work but not a practical solution when you are driving about.
Jul 10, 2009 | Uniden TRAX-430 GPS Receiver
Gqrmin 350 GPS Receiver wont turn on
Dead Battery? That makes no sense at all. He mentioned he was running it off the battery - " I was able to plug it in to a computer1.gif and unplug and was able to use it on the battery. Once I unplug and use it on battery, the only way I can power it off is by pressing the Reset button on the back."
The fact of the matter is that there is a well known issue with Nuvi 350 Power switch. I haven't taken mine apart yet (also bad power switch), but most likely the switch is defective or the solder joints are broken.
Sep 23, 2007 | Garmin nuvi 350 GPS Receiver
Uniden MapTrax GPS352 GPS Receiver Logo
578 people viewed this question
Top Uniden GPS Experts
Carlos Alvarez
Level 1 Expert
Oloyede Monsuru
Rochell Cruz
Are you an Uniden GPS Expert? Answer questions, earn points and help others
