Unable to pick up local channels using RCA DTA800 converter and Phillips SDV2750/27 antennae. Can pick up one local channel, but goes to squares constantly. What equipment do I need now to pick up local channels?
If you live a good distance from the TV station you may need a better antenna. Did you do a channel search on the converter box? You'll need the remote for the converter box to change channels, not the TV's remote.
Good day, I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog. The converter box will be set to channel 3, and you should set your tv's to channel 3 as well. Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan. When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separateChanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started. The converter box takes place of the tv's tuner and in essence disables it.
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Ah, the problem is likely your antenna. Make sure everything is properly hooked up, and that your TV is on and turned to either channel 3 or 4 (whichever the unit requires, or you can try both and see which works) then turn the converter on, and check the manual that came with it for a way to check for your antenna's signal strength.
If your signal is good, then use the menu button on the remote and look for an "autoscan" feature, or "autoprogramming", something along those lines, and let the unit look for channels for you (mine requires this before you can use it, not that it matters because my antenna signal is weak). From there you can access the channels manually.
I am not from that part of the country, so I can't say for sure, but check the following:
1) Are the UHF channels local and small stations? If so and under a certain power level, they are not required to broadcast in digital. THere may not be digital UHF channels local to you.
2) The changeover is required by law to occur by Feb 2009. Not all stations have made the change yet. You could still be in an area where the stations have not yet converted to digital broadcasts.
Make a few calls to find out which category yuo fall under above. If you don't fall into either of the above, update this and we'll look elsewhere for the problem.
Try bypassing your amplifier. I was getting an incomplete scan, and that solved the problem. I ran the scan without the amp in the line, then turned off the TV and converter and reconnected the amp.
