Question about Canon MultiPASS MP390 All-In-One InkJet Printer
PRINT IN BLACK WITH COLOR CARTRIDGE?
IS IT POSSIBLE TO SET THE MACHINE TO DO BLACK PRINTING FROM COLOR CARTRIDGE??
I HAVE RUN OUT OF BLACK INK AND WOULD LIKE TO USE COLOR CARTRIDGE TO DO BLACK PRINTING.
THANKS,
Even if you try and print black from the colour Cartridges to do this you would have to make the text a very dark green in colour. You will find after a little time the printer will stop work and a error will come up on the printer. Canon printer have this system in them where the printer will have ink count back when this counter gets to 0 the printer will stop and give you a ink tank error. the only way to fix this problem is to replaced the ink cartridge in the printer. This system is to protect the purged unit and the printer heads in the printer.
Posted on Dec 27, 2007
  • 102 Answers
Yes, you can print out in black from a color cartridge, however it is not advised as you will run out of colored ink twice as fast as it combines all the colors to get black.However it works great when your in a pinch and need black ink.
Just go to your printer properties when you print and the option will be in there someware.
2 Suggested Answers
SOURCE: PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Posted on Feb 21, 2009
How can I fix my ink problem?
It is possible the ink carriage and print head are very dirty and needs servicing.
Aug 25, 2014 | Brother LC51BK Print cartridge, Inkjet...
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Changing ink default to BLACK
Not possible.
Epson uses the black cartridge mostly, but also adds color to the black printing in order to keep the color inks from drying in the print jets on the printhead.
They also make lots of money that way...
===sorry===
Sep 14, 2009 | Computers & Internet
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
Want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Jan 24, 2009 | Dell 922 All-In-One InkJet Printer
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Sep 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Can you set default to print using only black ink?
Wow, what an incredibly unhelpful answer. Thanks, HP shill.
The answer is no. Selling ink is how printer companies make money, and they will do everything possible to make you buy more ink, even when you don't need it.
Mar 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Canon ip700 Printer Ink Question
sure..go to your print settings, and tell the machine to print in black only. That's a usual trick for when the color runs out, which is not unlike when it's missing. Of course, you might just want to replace the color cartridge, just to keep your printer happy, no?
Got backup?
Feb 07, 2008 | Office Equipment & Supplies
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
156 people viewed this question
old marine
old marine
