You need to adjust the air pressure screw in the pump filter housing,should be running at 5 pounds,low pressure will make it smoke and go out so turn the screw out.Also,check your lines for cracks.
The heater starts fine, but the gas flow is significantly reduced after a few seconds. Tried a...
(More)
The heater starts fine, but the gas flow is significantly reduced after a few seconds. Tried a different regulator but the same thing happens. Unit ran fine for almost a year, then without warning this gas flow problem occurred
Tries to fire but shuts down after a few seconds. I have already ran it a few times this week. Now...
(More)
Tries to fire but shuts down after a few seconds. I have already ran it a few times this week. Now won't start.
Turns on with flame and fan and after 5-10 seconds shuts off. When I plug it in again, the same...
(More)
Turns on with flame and fan and after 5-10 seconds shuts off. When I plug it in again, the same thing happens. I have tried new fuel with no change.
my heater will fire up and run then if i unplug it and plug it back in the motor spins slow and the...
(More)
my heater will fire up and run then if i unplug it and plug it back in the motor spins slow and the reset pops,if i let it sit for a couple miutes it fires up,the motor spins freelyand is not hot,help
55000 btu kerosene heater I ran great until i moved the heater to another room, plugged it back in...
(More)
55000 btu kerosene heater I ran great until i moved the heater to another room, plugged it back in an it ran for maybe 45 seconds then cuts off. Now when i plug it in, it does nothing. Can someone please help me?
