Question about Graphics Cards
Error code 43
I just bought an Acer computer with Vista. It has 2 graphics cards, onboard ATI 1250 and a nVidea 7300 SE right out of the box. I play war games, COD, CODII, MOHAA, MOHHAB, and afew others. I plugged my monitor into the 7300 SE card and it worked fine for a couple of days then went ape shit. I had to plug back into the motherboard graphics card to view. In the device manager it shows both display cards. On the properties of the 7300SE card it says that windows has stopped this device due to problem. I have tried uninstalling and reinstalling the driver for the 7300 SE but when I plug into it, I still get nothing, black screen.
    Problem Solver:
  • 19 Answers
Re: error code 43
What you have to do, with your monitor still plugged into the onboard, is disable the onboard controller then restart.
Your screen will go to 640x480 during this process, but no worries.
Once you've logged back in to vista, open up your device manager again to make sure that your card is now enabled. If not, enable it. Also make sure that your cards' driver sortware is updated.
Switch your monitor over to the card now. No need to power down.
Open display properties, set your dual monitor setup to default on the single monitor that you do have plugged in and reset your screen resolution... and maybe even upgrade your monitor driver from generic to specific if you want.
The issue with nvidia cards isn't with vista or nvidia at all. It's a simple matter of driver conflict between the card and the onboard chip. You just have to tell vista that you'd like to make the card the priority adapter by disabling the onboard.
However, disabling the onboard DOES NOT make it unavalable to you. You can still utilize it in a dual monitor setup as a generic adapter without conflict.
Posted on Apr 09, 2009
  • 102 Answers
Re: error code 43
Did you enable the 7300 SE through display properties after you reinstalled the drivers?
Posted on Dec 27, 2007
0 characters
3 Points
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
Aug 07, 2011 | Dell ATI RADEON X300 SE, (128 MB) PCI...
I have an asus m2A vm hdmi mobo. I needed a better graphics card for some games. I installed a Sapphire Radeon 5570 2Gb DDR3 HDMI card. The bios selection of PCI-E, VGA or PCI is set at PCI-E. I get no...
you will have set your computer to failsafe defaults or optimised defaults first to get your resolutions to there defaults first
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers if your computer came with a motherboard disc the drivers could be on it or you could download on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need This release for all Radeon family products updates the AMD display driver to the latest version. This unified driver has been further enhanced to provide the highest level of power, performance, and reliability.
hope this helps
May 30, 2011 | Sapphire 100293-2GL RADEON HD 5570 2GB...
Graphics card wont work after os change
if u have downloaed drivers those are not supporting then you have to un-install graphic drives and try againe it will work or install menualy
1 go to Divice manager
2 setlect graphics
3 run that it will ask you for run software select that foloder where is your deivers and run menuly
hope fully it will detact
Apr 20, 2010 | Graphics Cards
Computer - Intelchips 82945G - Error Code 43
When your computer loads, after you power it on, it gives you an option to go into the CMOS. You can disable integrated periferals there. If you don't know how, check your system documentation
May 10, 2009 | MSI Graphics Cards
My computer won't detect ATI RADEON SAPPHIRE X1550 256MB
go to bios and enable it to detect graphics cards most bios have an option for onboard only or onboard and external graphics adapters
May 04, 2009 | Sapphire ATI RADEON X1600Pro 512MB...
ATI Radeon HD 4350 (Shapphire Model)
If your computer keeps shutting down may be with the Driver, try to reinstall the driver or repair it, if you have the driver.
Jan 25, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Error code 43
When going from the onboard Video  to the Video card, on all the most computer I have seen,, you need to go into the BIOS setup screen and turn off the onboard graphics to avoid a software conflect, which it appears that you are having..
Jan 21, 2009 | Graphics Cards
Error code 43
Uninstall both video cards, disable the integrated card in the bios, and then reinstall the stand alone video card. If you continue to have problems, please post what motherboard you use and what error code device manager gives.
Jan 14, 2009 | Nvidia GeForce 6200 AGP Graphic Card
ATI radeon xpress 1250 for laptop
Have you tried the windows update,usually for vista they have a built-in WDM drivers for ATI, and right now you may want to use that for the meantime if the computer did not recognize the exact model number also when using the windows update it you can check if microsoft has a new WDM driver for your video card.
The video card is a built-in video card on the mobo, right?
This this link
If you have a Vista Business 64 bit click the link below
Sep 19, 2008 | Graphics Cards
Graphics Cards Logo
1,112 people viewed this question
Top Graphics Cards Experts
phoenix chi
phoenix chi
Are you a Graphics Card Expert? Answer questions, earn points and help others
