Question about Zebra TLP 2844-Z Thermal Label Printer
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
Hello I am facing problem printing on glossy (shiny) labels using TLP 2844 EPL. It doesnt print properly..its very light and sometime it doesnt print at all. I am using part no 800130-202 ribbon and tried all darkness setting as max is 15. I tried printing on other heavy ZPL printers and it prints with head darkness set to 30. I am not sure why the problem is with TLP 2844 is it the head heating is not sufficient? cause this ribbon is compatible to TLP 2844 as per zebra. Please help me with a solution.
  • MILBERDUGO19 Sep 23, 2008
    CUANDO COMIENZA A IMPRIIR SE QUEDA COMO SI EL PAPEL QUEDARA PEGADO
  • Anonymous Mar 28, 2014
    We have a TLP 2844-Z and we have tried to re-calibrate it, but it still only prints the right half of the label information on the left half of the label. How do we fix this?
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Posted on Jan 21, 2008
Zebra TLP 2844 label gaps
you can try contacting zebra. im not familiar with that model.
Aug 25, 2017 | Zebra TLP 2844 Label Printer
Everytime i turn on my zebra tlp 2844-z it prints 2 blank labels.anyone please help me to solve this problem
Are you using the correct labels?
Direct Thermal Printers use different labels than printers with ribbons.
If you print a label using labels from a ribbon printer in a direct thermal printer they will come out blank.
Jan 28, 2011 | Zebra TLP 2844-Z Thermal Label Printer
When using this now with create-a-label the only
This is a Create a Label issue, not a printer issue. I suggest that you post under that heading, or call their tech support for help. having said that, your 2742 is an EPL based printer, try installing another EPL printer in your application and see if that helps. Other EPL printers: Eltron Orion, 2442, 2543, etc.
Jan 26, 2010 | Zebra Eltron TLP 2742 Thermal Label...
My zebra tlp 2844 is loaded with perforated labels 2''x1.38''. each time it prints a label, it spits out about 20 blank labels, then the light goes red and won't print again.
Calibrate it! Hold down the green feed key while powering on and then release when it flashed red. If this fails, look at the page size in the driver or the "Q" and "q" EPL commands that you are sending from you application. Make the proper dots to inches conversion and try again.
When you say 2 x 1.38, it sounds like the labels are 2" wide by 1.38" long. I do not believe that the length is below a specified minumum, but this information is not on the spec sheet. Try tech support if all else fails.
Jan 13, 2010 | Zebra TLP 2844 Label Printer
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
j.zh
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Cant print on butterfly label with Zebra TLP 2844 printer
This is a problem of label sensing.
You are probably using the Gap sensor on the 2844, unfortunately the shape of the butterfly labels means you are sensing the wide gap between the labels in the centre, so it will not print anything in the apparent gap area on both ends of the label.
What your label or system supplier should have done is supplied you with the same labels but with a 3mm wide black mark on the underside of the label backing paper, centred between the labels. You can then change the printer sensor setting in the driver to Black Mark. You will then be able to print anywhere between the black marks.
Any problems with this contact us directly at Lancer labels Ltd
Nov 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
738 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
