Question about Sirius STILETTO 100 MP3 Player
Stiletto constantly powering off
Just opened up the box for the stiletto, and as i powered it on, it has constantly made an attempt to power on, but before it goes to the main screen it shuts off, and then powers on again. This process of powering on and then turning off is repetitive, and has been happening for the last several hours. (the batteries are also fully charged). not sure what is wrong with it, or if its defective.
  • pj stodda Jan 12, 2008
    I have had this stiletto 100 for just over 1 year. It had been working just fine.
    On Jan 8 2008, while it was powered on in it's docking base, playing via satellite feed the buttons became unresponsive. I could not change stations, switch to recorded playback or internet. It would not shut down using the power button so I removed the battery.
    I re-attached the battery and the unit began to boot up with the sirius dog logo as usual, but then instead of the main home screen, a message appeared ---"please wait, restarting".
    The unit then re-booted it self.
    Before completing this boot the unit now switched to say "shutting down".
    The unit then continued to constantly re-boot it self, never displaying the home screen. It only stopped when I removed the battery.
    I have tried to power it on several times with the same results every time.
Solution is downloading the sirius recovery software from sirius.com My radio would not connect to my computer because it would not fully turn on. disconnect the battery. Hold the DISPLAY and OPTIONS button on the radio face when reconnecting battery. Connect to PC and Sirius Recovery Program will pop up. Run program, takes approx 10 to 15 min and radio works good as new.
RUNNING PROGRAM WILL ERASE YOUR LIBRARY ON YOUR RADIO....
Posted on Jan 11, 2009
  • 97 Answers
Your Stilletto has most likely been corrupted in the flash memory area that contains the OS. Sirius recommends the following;
SIRIUS Device Recovery (SDR) is a software application that helps you recover your Stiletto (SL2, SL100 or SL10) in the event of a complete system failure.
The SIRIUS Device Recovery program retrieves the latest version of software for your Stiletto from the Sirius website. NOTE: Performing device recovery WILL ERASE the entire contents on your Stiletto: all music, Sirius recordings, channel presets and any user preferences. The Stiletto will be reset to its original factory state. You can perform the revovery from the Sirius Studio software that came with your device or http://www.sirius.com/mysiriusstudio
Posted on Mar 18, 2008
Message constant check screening. screen is clean how do i fix?Where is sensor?
you need to reset the fault
turn off the mains hold in either the program select or on off or start stop or a combination of them
and power on at the mains
same thing like a sky or cable box to re-init it
then this clears the fault
Dec 01, 2014 | Kenmore Washing Machines
Will the Sirus Stiletto II radio work with an earlier Stiletto dock, either auto or home?
no. stiletto 2 will not fit into earlier model stiletto dock. i order the older model boom box by accident. i tried but will not fit.
Sep 18, 2010 | Sirius Stiletto 2 Satellite Radio Receiver
Stiletto 2: Device works, but no radio
I've had this same problem happen a number of times to mine and all I do to fix it is to disconnect the battery for about 20 seconds and then reconnect and power on. Has fixed it every time (so far)! Hope this helps!
May 27, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
Batter AC constant switch back nd forth
several possible causes -- bad power supply (AC adapter, bad battery, bad connection to AC adapter, bad connection to battery - or both.
May 26, 2009 | Acer Aspire 5040-3810 Notebook
Stiletto2 sometimes has static while playing mp3's from exp. card
I also own a Stiletto 2 and I have noticed this same problem, but only when playing MP3's in my car. What I have found is that if the volume on the Stilletto is too high it creates distortion. The solution is to turn down the volume on the actual Stilletto and just use the volume on the car stereo. Problem solved everytime.
Nov 21, 2008 | Sirius STILETTO 100 MP3 Player
Sirius Stiletto 2 Problem
That's one of several problems my Stiletto 2 has. The only solution I've found is to "reboot" the unit. You'll have to remove the unit from the cradle, pop the back off, and remove the battery for a few seconds. Then put everything back together and power it up. It will take a minute or two, but once it reboots it should be fine.
Aug 15, 2008 | Sirius Audio Players & Recorders
I'm recieving a strong signal on my stiletto 2 but no sound on the radio. The MP3 player works with headphones and so does internet radio.
You need the firmware upgrade from the Sirius website:
Bug Fixes
· Reduced incidence of “acquiring signal” and “antenna not detected” messages
while the radio is installed in the Stiletto Vehicle dock (SLV2)
· Improved audio quality and distortion reduction
· Reduced incidence of long block recording and Radio Replay corruption
How to Get this Release
Updating over WiFi:
Subscribers may update Stiletto 2 over WiFi by following these steps:
1. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
2. Turn on the Stiletto 2 and press the HOME button
3. Use the MEDIA DIAL to scroll to Internet Radio
4. Press the SELECT button to connect to Internet Radio
5. Tune to your favorite station and let it play for several hours.
6. Follow prompts on screen to complete the update, then power cycle your radio to
apply the updates.
7. Next go to HomeSettingsDeviceDevice info, if the baseband version is
already 00.14.94 you are done. If not, continue to the next step.
8. Reconnect to Internet Radio and listen for at least 15 minutes.
9. Disconnect, and tune to Satellite Radio. Updating Sirius will be displayed for
approximately 5 minutes.
10. Once the message clears, your update should be complete. Go to the Device
Info screen to verify the update has been successful.
Updating using My Sirius Studio™:
Customers without WiFi access may update using My Sirius Studio™ running on a PC
with an active internet connection:
1. Launch My Sirius Studio™ on your computer. Be sure you are running the latest
version of My Sirius Studio, currently version 1.5.1.
2. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
3. Turn on the Stiletto 2 and connect it to your computer using the USB cable
supplied with your device
4. In My Sirius Studio, click on the gear icon next to the device or go to File
Device Settings Check for Software Update.
5. Follow the instructions that appear in My Sirius Studio™ to complete the update.
Please Note: During the update, your media library must be re-built. If you have a
large amount of content stored or a microSD™ card installed, the process can last
for as long as 10 minutes. During this time the message “updating media library” or
may be displayed.
6. After disconnecting from your PC it will be necessary to power cycle your Stiletto
and connect to Satellite Radio to refresh your channel list.
For additional questions regarding your Stiletto 2 or the SIRIUS service, please refer to
the product manuals. You can also reach the dedicated Stiletto Technical Support Team
at 1-800-869-5364 from 10 AM to 10 PM Eastern Time Monday through Saturday, or by
email at customercare@sirius-radio.com.
Jul 06, 2008 | Audio Players & Recorders
Stiletto Only charges via usb (no wall or dock power)
return it is you can. Its not suppoused to "charge" via USB, it is only ment to be self-sustaining not charge. Contact Sirius for Warranty Return info.
Feb 11, 2008 | Sirius STILETTO 100 MP3 Player
Plasma turened off and red light flases twice
Red flashing x2 = Panel power supply fault
It would be easier to replace the power board than attempt a repair at component level (dangerous voltages)
Oct 13, 2007 | Pioneer PureVision PDP-504HDE 43 in....
Sirius STILETTO 100 MP3 Player Logo
1,277 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
