Question about Epson LX-300 Matrix Printer
Printer my printer gets jammed & only some of my data is printed & then it stops printing so wfat must be the problem @ what i should do to solve this?
    President:
  • Epson Master
  • 2,022 Answers
See it is dot matrix printer so you need it littler bit servicing just apply oil or any lobricant on the steel rod of the head and clean it and move the printer head manually make sure your printer is off position.this will really improve your printing . and also try to install the printer driver .
bye
Posted on Dec 27, 2007
How to stop printing
1. Turn off the printer.
2. Unplug the data cable going into the printer.
3. Remove the offending print job from the computer.
4. Remove any jammed paper as a result of Step 1.
5. Turn the printer back on.
Jul 04, 2014 | HP LaserJet 1018 Printer
Keeps showing 900.57 firmware error and the paper gets stuck
Power the printer OFF and ON. Send the same file to the printer, if file has not been released from the print queue then delete all pending print jobs out of print queue.
Disconnect all data cables and power the printer OFF and ON. If the printer returns to READY, Reconnect the data cable and try printing again. If you are getting a paper jam error, please take not the error code and locate the jam. For further assistance, please contact Lexmark Technical Support.
Apr 06, 2011 | Lexmark T652DN MONO LASER PRINTER...
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Paper jams. Printer was cleaned, but it still jams.
Whare does the paper jam at?
It may be a fuser problem.
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. if not then the fuser
Let me know..
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 15, 2009 | Samsung CLP 315 Laser Printer
Attention light, print stops.
either you upgreat memory or print order less than 50 pages at a time.
Mar 14, 2009 | HP LaserJet 1320n Printer
All lights are flashing not printing
Might have a paper jam in area of toner and drum cartridge that may need to be removed. Typically this will solve the issue.
Feb 11, 2009 | Brother HL 1430 Laser Printer
Card jam
You have to change the roller just inside the picker roller.
Sometimes the glue that holds the "cleanig roller" loosen from the pin.
Sorry, bad english... :D
Jan 30, 2009 | Datacard SP35 Printer
Canon imagerunner c3200 stuck in processing data
If you don't print via a server,you can turn the iRC3200 off...then back on and that will clear the print jobs.
If after doing this it STILL has a traffic jam in the print que when trying to print the same document then stop sending THAT particular document as the document has a formatting issue and NOT the printer.
If you DO use a print server then you(or your I.T Professional) need to go to the server and clear the print jobs from the server.
Aug 06, 2008 | Canon imageRUNNER C3200 Copier
Printer will not print
It turned out to be a paper jam. I was getting the wrong msg from the printer. I notice that U have charged my bank acct. 4 BOTH of ur plans, Since I solved the problem myself, pls rescind these charges. Thank you. jrfoley1@ juno.com
Jul 12, 2008 | Office Equipment & Supplies
Epson LX-300 Matrix Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
