Question about Blaupunkt Travelpilot RNS-149 CD Player
Volume control I have had two of these units and like them but the volume control would not work on my first one and now the second one is doing the same. Any suggestions (bsdenes@yahoo.com) Appreciate
If this doesn't work try a can of compressed air to blow into the buttons to clean out the dust build up.
Posted on Dec 28, 2007
    Scholar:
  • 143 Answers
Clean the copper contacts on the face plate & the head unit with alchol or a coton bud pre sprayed with WD40.
Posted on Dec 27, 2007
How do I adjust the speaker volume on a Kindle Fire 8 HD?
The volume button is normally on the side, but second generation models have a volume control on the back of the unit,,,
Apr 17, 2017 | Tablets & eReaders
Cat stepped on remote TV went black have sound but no picture i have tried every menu option?
Try doing this:
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control
for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote
control for more than 3 seconds.
9.1.2. Exit
Disconnect the AC cord from wall outlet.
This is straight out of the service manual.
Regards,
Joseph Van Buren
Aug 01, 2014 | Panasonic TH-42PX75U 42 in. Plasma HDTV
Volume decreases during use
Very simple. It is not a defective unit. Simply a matter of volume attenuation, hold the "function" and "grove"keys for aprox 5 seconds until a message saying vac off appears. Problem solved. Resets itself eveytime the unit is turned off .
enjoy!!!
Nov 16, 2013 | Sony RDH-GTK1i Hi-Fi Music System
Volume control not working properly on my remote control, all other buttons are fine, do I need a new remote or canI get it repaired if so where? Onkyo HT550 unit
Did u tried disassemble remote control and clean PCB with clean cloth? Also u can take rubber part of remote and wash it carefully in soaped water . While u have it disassembled check for bad solder connections at IR LED on remote controller . Regards .
Oct 01, 2012 | Onkyo SKS-HT500 System
Where do you hook up outside speakers
'Outside' is not a choice on the unit.
If you want to drive a separate amplifier with speakers somewhere you could replace the Main Channel Pre-Out jumpers with an RCA-Y-adapter and slave the second amp and speakers to this unit's volume controls; or you could attach a second amplifier to either TAPE REC OUT pair and the external amp and speakers would have independent control of volume locally.
Jul 03, 2011 | Yamaha DSP-A3090 7-Channel Amplifier
The control panel is locked. Attempting to wash my clothes i plug in the washing machine and it says control lock and nothing else is working
Maybe their is more to it but have you attemped to unlock the controls..on the lower right side of the control panel there is a button for the end of cycle signal (volume) if you push and hold down on this button for 3 to 4 seconde it will lock all the buttons and the unit will do nothing ,if there all ready locked push and hold this button for 3 to 4 seconds and they will unlock and unit should work as normal I hope this will help If you have a different concern after this write back and we will see what else we can do to help you out...good Luck
Sep 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Genius HS-03U Volume Control Help
It's not fixable.
Set as default audio unit to "USB audio device", because Genius HS-03U control the volume only sound device by default.
Headphones improperly trying to adjust the volume of "alien" audio devices, such as second sound card, if it is selected as the audio output device by default.
Oct 20, 2009 | Genius HS-03U Headset
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
Volume control on in-dash unit not working properly
Sony CDX-GT300 volume control stopped working. Radio is either on full-blast, or you have to turn it off. Any solutions? Thanks!
Aug 03, 2008 | Car Audio & Video
Blaupunkt Travelpilot RNS-149 CD Player Logo
168 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
