The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp. The problem could be the electronic control if
you have one or the mechanical linkages.
If it is freezing, either you need to turn both temp down to 2nd to lowest setting. Cold air does sink, so that is why crisper gets colder. There is a flap and vent for air between the fridge and freezer. The flap can get stuck in one direction, or the acutator that moves it can become faulty. A leaky door seal will also make the opposite compartment colder.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire GLRS263ZD Side by
Ice maker model uki1500axx. Maytag refrig freezer on top. Problem is the plastic supply line that...
(More)
Ice maker model uki1500axx. Maytag refrig freezer on top. Problem is the plastic supply line that runs up the back and slips into the piece that goes into the freezer keeps leaking and coming out. There is a metal clamp on it. I loosened the clamp, re-inserted the tube then re-crimped the clamp. It continues to leak and come loose. Sounds like it should be very simple but it is driving me crazy. Thanks in advance.
After cleaning my Frigidaire Gallery (GLRS263zdwo) it no longer cools. (Supposedly it was cooling...
(More)
After cleaning my Frigidaire Gallery (GLRS263zdwo) it no longer cools. (Supposedly it was cooling before the cleaning but I'm not sure. So for the moment lets assume this is true.) It does have power, everything else seems to work. It also feels like cool air is coming out of the bottom but that might just be a fan running underneath. I know there are a few test modes modes but I don't know how to activate them or deactivate them. If I got water while cleaning it in the center cooling area "vent?" would have caused the issue? I don't really have more information as it came with the house.
Our freezer began to defrost fron the top today and now on the lower half frost is formed on the...
(More)
Our freezer began to defrost fron the top today and now on the lower half frost is formed on the back. The fridge seems to be a little warmer but still ok i guess any suggesstions on how to fix?
