Problem for Panasonic Microwave Ovens
Generic problem for all Panasonic Microwave Ovens
I have a Panasonic Inverter Model NN-...
I have a Panasonic Inverter microwave Model NN-T664.It acts as if it is not getting any power--then touch the door around one of the 2 latches that keeps the door closed it will come on--sometimes it will run for a few seconds then cut off. Is it worth having repaired ??
Best Solution
posted on Oct 11, 2009
Rank: Guru
Expert
Rating: 89%, 5324 votes
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the switch mount is broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
If you only need a
switch, you can order a universal type here for $5 postpaid.
Was this helpful?1 person thought this was helpful
Asker's Testimonial
THIS SOUNDS LIKE EXACTLY WHAT THE MICROWAVE IS DOING.. I BELIEVE NOW IT MAY BE WORTH REPAIRING. THANKS
" - conner911
Popular Solutions for Microwave Ovens
Questions and Unsolved Problems for Microwave Ovens
ge over the counter microwave height 14.5 30 inches wide 15 inches deep overheating
I can not afford an integrated microwave. can i put a much cheaper free standing microwave into a...
(More)
I can not afford an integrated microwave. can i put a much cheaper free standing microwave into a built in microwave cabinet.
microwave says LOCK and will not function
while my GE Spacesaver microwave door handle and part of the door plastics were broken, the...
(More)
while my GE Spacesaver microwave door handle and part of the door plastics were broken, the miscrowave was functional. Now that I replaced the entire door assembly, the microwave is not functional and the inside light remains on permanently.
The Microwave was working just fine yesterday, i heated 1 potato, and sweet potato. Now this...
(More)
The Microwave was working just fine yesterday, i heated 1 potato, and sweet potato. Now this morning. The turntable turns, the inside light comes on, but nothing get heated up. Can i actually Fix This, or should i just buy a new microwave. The Microwave is about 7 years old.
