First of all check what is the status of the wireless Light.Is it White/Blue or Amber? If Amber then swipe in your finger on the Quick Launch button to turn it on.If it is not working then Make the Connection in the following manner: The Ethernet cable comming from Modem goed to the WWAN port of the Linksys's Back Panel.Connect the Other Ethernet Port into the Port 1 of the router and the other end of the cable to the NB's Ethernet port.And then open the Internet Explorer and type in at Address Bar 192.168.1.1 and then press enter.The Gateway page will prompt for username and password
The Default user name is:admin and password is:admin.type it over there and login.
go to the wireless-->Security Settings and select the type of security ,select wpa and then make changes according to your requirements...
Testimonial: "Thank you for your quick response that was fast. "
I did they offer so much mumbo jumbo and you have to pay for tech support just bought the item.
Thank you. I called Linksys and informed them of problem. In run Type "services.msc" screen loaded go to windows zero it should say automatic..... if not right click on it select automatic...........mine was set to disable, reason for error.
once set to automatic piece of cake.
