Question about Philips ProScreen 4750 Impact Multimedia Projector
Double image or shadow image
My project has dubble or shadow image and the clarity is poor. All other things are working fine and recently changed the bulb.
Need advice as to whether the video card may be faulty or it is only a minor problem of adjustment inside the unit.
Appreciate your help
Bhaskar
Bhaskarswamy52@yahoo.com
    Problem Solver:
  • can u tel me which section is the video card and i can order the replecment
Posted on Sep 21, 2008
We recently had the same problem with our church projector and we too had just changed the lamp. I read somewhere while searching for an answer that if the cable input is loose it will cause double vision of the text. Sure enough, the cable was loose and after tightening the text cleared up immediatly.
Posted on May 05, 2008
    Problem Solver:
  • 9 Answers
Dear Sir,
I am willing to buy over your Philip 4750,
pls contact me at the soonest master300p@hotmail.com (04/03/09)
regards
Mr Cheong
Posted on Mar 04, 2009
We have a Panasonic PT-56wx53 projection TV that has a double image problem. We have tried to fix the issue with the convergence feature, but the blue color will not line up, red and yellow working fine. ...
Does this problem happen all the time ? What I mean is , if your watching the local news thru your cable/sat box does ot happen, or just when using aux imput. Either way, double image, or shadowing, is usually caused by a defective wire. Troubleshoot each unit, unplug everything and start from scratch.
Mar 06, 2011 | Panasonic PT-56WX53 53" Rear Projection...
There is a black shadow and the light is new.
Black shadows can be caused by several things. If the bulb/s was/were recently changed then its possible that part of the black material that covers the interior, or some other "object" has fallen into the light path.This can also be caused by "burn in" depending on your TVs technology. Thats where an image has been on in the same spot without changing for a long time, like with a video game etc. this cannot be fixed, the device that make the image must be replaced. Lastly, if the set is DLP or CRT technology a magnet or magnetic tool can warp the image if left close to the tube. All you would have to do is remove the magnet to fix this.
One last thing...if the shadow is around everything on the screen, like a real shadow, then your set need to be aligned. If you replaced the bulb/s yourself, you can bet this is the problem.
Most of these sets have a combination of physical and electronic adjustments that need to be made when any of the video producing elements are replaced.
Feb 20, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Shadows and text curved. Double images
The convergence IC's need to be replaced. The generic part # on them is STK392-110. This is not easily done by yourself.
Apr 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
53 Hitachi Rear Projection TV with shadows and double images
Does the magic focus work on your set ?
If it doesn't you must replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Jan 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Hitachi ultrascan hd 42 in
The problem you are facing is a common problem in all rear projection TVs. It's called convergence. If you go into your menu there is an adjustment for it. if it doesn't move back into alignment then you have a more serious problem in the convergence circuit which will require replacement of components.
C-Dog
Feb 05, 2008 | Hitachi 43GX01B 43" Rear Projection...
DVD player producing poor colour image
Go purchase a DVD player cleaner. It will look somewhat like a DVD/CD and will clean the read heads. Often the issues is dirt/dust.
Semper Fi,
Z
Jan 29, 2018 | Televison & Video
P1110 Blurry/dubble image
your beam needs calibration take it 2 a pro... windman
Jan 28, 2006 | Dell UltraScan P1110 21" CRT Monitor
Philips ProScreen 4750 Impact Multimedia Projector Logo
1,126 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
