Question about PDAs
Security Permissions issue when installing certificate
I'm trying to install a certificate file provided by my Company's helpdesk to configure a server source on Gigabyte gsmart i128 PDA for downloading my official mails into gsmart i128. When I click on file it states "You are about to install xxx, a certificate file issued by yyy. Do you want to continue? On clicking "Yes", it gives error message "Security Permission was insufficient to update your device". Please assist on how to install this certificate.
Re: Security Permissions issue when installing...
I don't know how big your company is but given that it has an IT help desk it must be of some size. Security has to be tight and it may well be that installing the certificate can only be done on certain units or by certain people within the IT department. I would have a word with them (if you have not already)
Posted on Dec 27, 2007
0 characters
3 Points
When i install a sis or sisx always say file corrupted!! can you help me with this?
for showing certificate error problem.......
>download from website signtools3.23
and open this software
> the specific software whatever u want to unsign
> the certificate file(that will available insigntools software)
> the key file(that will available insigntools software)
>then signature it
Jul 27, 2012 | Nokia N95 Smartphone
MC70: the scanners are becoming slow, not loading and no...
You could try and blank the Application folder. This would require installing any software and settings you require:-
Clean Boot Files for WM5
Clean Boot Files for WM6
Also there is a firmware update for the Siemens MC75 v2 GSM card. That may help your SIM issues.
If its not that try and clean you SIM card and contacts.
Hopethis helps.
Ifyou need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.comor TEL 01202 620955
May 17, 2010 | Symbol MC70
Hi, i want install the smartphoneaddcert.exe in my Dolphin 7850
This file is a Win32 executable zip file. Run it on your PC. You'll be prompted to unzip the contents. You'll notice that it will generate a number of files in the directory you have specified. One of them is 'SpAddCert.exe'. Copy only this file to your PPC device. There, create a folder named 'Storage' in the root of the device (not in the storage card!), and copy your certificate(s) - .cer files - to it, since it's the only place where SpAddCert searches for certificates. Run SpAddCert on your device and follow the prompts. After installing your cetificate(s), restart your device.
Hope it works for you.
Cheers! Carlos
Apr 19, 2010 | HHP Dolphin 9500 Pocket PC
When I try to install my ebooks library for reader it says to check my internet connection, which is fine!!! it will not finish the installation.
If attempting to connect to the Reader (eBook) Store by Sony on a computer that is connected to a network through a proxy server, contact your IT support specialist for assistance in configuring your proxy server settings to allow access to the Reader (eBook) Store by Sony. It is not possible to adjust these settings through the Reader (eBook) Library software.
  1. Check your security software settings. Some security settings may not allow the Reader (eBook) Library software to access the Reader (eBook) Store and will need to be adjusted to allow access to the Reader (eBook) Store. Determine if the security software is causing the issue.NOTE: Various different Internet security or parental control software may block access to the Reader (eBook) Store. Some software may request a password to unblock the store site. If a password is requested, enter your password to access the site.
    1. Temporarily disable the security software.
    2. From in the Internet Explorer software, on the menu bar, click Tools , then click Internet Options .
    3. In the Internet Options window, click the General tab
    4. In the Browsing History section, click the Delete... button.
    5. In the Delete Browsing History window, in the Temporary Internet Files area, click the Delete files... button.
    6. In the Delete Files window, click Yes .
    7. Attempt to access the Reader (eBook) Store Web site through the Reader (eBook) Library software.If you are able to access the store with the security software disabled, the security settings will need to be adjusted. If you are still unable to access the store, continue with troubleshooting.
    8. Re-enable the security software.
    NOTE: The steps to adjust the security software settings varies by manufacturer. Consult the help files of the software or contact the manufacturer for assistance. A list of contact information for some popular security software.
Dec 26, 2009 | Sony Reader Pocket PRS-300
To get past this error you must (a) change the date of your mobile to a previous date and also (b) in the settings you must set it to Not Check the security certificate.
Oct 27, 2009 | Nokia E90 Smartphone
Moto Q can send, however can not recieve new messages
First thought is that your certificate expired. That would explain why it would work one day and not the next.
Next thought is that you made a change to the IIS server they use to sync. Try deleting the partnership on one phone and recreating it.
If this helps please vote for my solution.
Apr 16, 2009 | Motorola Mobility Moto Q
Certificate error contact application supplier error msg
Send me the theme File i can get it signed for u.or visit this link u will get an idea on how to sign files.
Dec 16, 2008 | Nokia N78 Smartphone
I accidentally deleted the certificate
try to download themes fro your mobile from or you can get all new themes try to install directly or through p.c via usb or bluetooth
Oct 04, 2008 | Nokia N81
Can not install Root Certificate
phones with win 2003 suppor digital certificates in DER format. If you have a PKCS12 certificate you will need to use a special program to import the personal and root have to use a utility like P12imprt/Crtimprt/Enroll to install the certificate, run the program and follow the instructions to install the certificate.
Sep 14, 2005 | HP iPAQ hw6515 Pocket PC
PDAs Logo
362 people viewed this question
Top PDAs Experts
Are you a PDA Expert? Answer questions, earn points and help others
