i can not print because it says the printer is busy or "attempting to connect". it can not recognize the ip address and i have verified it as correct...it used to print and now nothing
Have message on screen that says scanner failure. Followed troubleshooting steps all ok. I think...
(More)
Have message on screen that says scanner failure. Followed troubleshooting steps all ok. I think problem may be in the bulb or what ever the light source is. I was copying some pappers and had open the ink door for a problem and when reclosed it wouldn't work any more and showed this error
The following is my exact problem...can it be repaired? Hard to tell if piece is broken. "My...
(More)
The following is my exact problem...can it be repaired? Hard to tell if piece is broken. "My faxes are not printing. The error message says there is a paper mismatch and tells me to remove the transparency and press enter. Problem is, I'm not using transparencies, just normal paper. Problem started when I noticed a small, clear, rectangular plastic piece in my paper tray. I think this might be the problem, but I can't tell where to reinsert the piece. Help!" from 2008 on your site. Thanks!!
I have inserted a new ink cartridge and it will not dispense the ink. I have removed all tape from...
(More)
I have inserted a new ink cartridge and it will not dispense the ink. I have removed all tape from the cartridge.
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone...
(More)
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone line is good. I probably have it hooked up wrong but I do not know. Help!
