Question about Samsung SCX 4200 All-In-One Laser Printer
Defective brand new cartridge or defective printer
Hello there guys,
I'm wondering if you can help me with this.After having used without any problems about 1000 pages out of a starter toner , I bought a brand new original samsung toner cartridge for my Samsung SCX-4200 but as soon as I placed the cartidge into the printer there were immediately very loud cracking noises and output of blackened pages with vertical lines.Thinking that my printer might be defective,I bought another SCX-4200 all-in-one just to verify and when I used the same toner cartridge,exactly the same thing occured so I returned the printer.Is it possible that I might have a defective toner cartridge even though it is an original samsung toner cartridge or is the printer somehow suddenly defective after outputing about 1000 pages out of a starter toner without any problems.One thing to notice though is that, I was still using the printer for a while,when it was indicating that it was out of the initial starter toner and same very loud cracking noises occured when the starter toner was finally out of juice.
Thank you
  • Anonymous Mar 24, 2008
    printer does not recognize its oun cartrige
Please give the suggestions for colour printing in samsung- 4200 printer
Posted on Dec 26, 2007
My epson c59 says the ink cartridge is expended, and the it is not the genuine ink cartridge of epson, what will i do now, but its new
You may have a defective Epson cartridge (internal ink level monitoring circuit) - Epson uses a piezo-electric sensor (in all their cartridges) that is subject to this type of failure...the cartridge may need to be replaced.
However, if after replacing the T0753 cartridge with brand new Epson Original ink cartridge, does NOT correct the problem, then you may have a defective PRINTHEAD in the printer (i.e. permanent electrical sub-assembly which the cartridges plug into).
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem/troubleshooting resolutions or advanced printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 22, 2013 | Epson Stylus Color 660 InkJet Printer
Printer will not accept new cartridges. Printer is new and wants original cartridges to initialize ink system. Original cartridges are not availible. Tryed reset but did not work.
HP printers will not accept refilled cartridges. Are you trying to replace your empty cartridges with refilled cartridges? There is a computer chip in the ink cartridge that tells the printer when it is out of ink. If you try and refill it yourself, the printer will not recognize that it has been refilled without replacing the computer chip in it.
I think your printer is telling you that it needs HP brand cartridges that are original and not refilled cartridges. There is no way to "reset" an hp printer to get it to use an off brand or refilled cartridge that has not had the chip changed.
You can pick up a good refilled cartridge at a professional company who knows about changing the chip for less then a third of the regular price of an HP cartridge in a department store. However, HP does not want you to use refilled cartridges and should something go wrong with your computer and they find out that you were using them they will void your warranty on your printer.
If you are not trying to replace HP brand cartridges with refilled or off brand versions, I suggest your return them to where you bought them and exchange them. They may be defective cartridges.
Hope this helps?
Nov 11, 2010 | HP C6250 InkJet Printer
Cartridge is not properly installed...
The chances are that the chip on the cartridge is defective. Have you tried another cartridge? If you can, take the defective cartridge back to the vendor and get a replacement or refund. If it worked once, it is likely the cartridge and not the printer.
May 29, 2010 | Canon PIXMA iP1300 Printer
I get an error message on my Lexmark X2500 All in One that there's a problem with the ink cartridge. As instructed I removed and re-installed the cartridges. I have also cleaned the connectors with a damp...
Hello. It seems that you have a mechanical/hardware problem in the printer itself. Remove the cartridges from the printer. Unplug the printer from the power source. Plug it back to the power source after 10-15 seconds. When the printer's ready, insert the cartridges and make sure the cartridges are properly seated and locked in the carrier. Make sure there's no foreign objects blocking the carrier. Close the cover. Let it print the alignment page all the way through without cancelling it. If it still makes the banging/knocking sound, I would advise you to call Lexmark. That is a sound of a defective printer already. Good luck!
Apr 10, 2010 | Lexmark X2500 All-In-One Printer
Hello my 7590 printer will not print in cyan
The chances are you have a defective cyan ink cartridge. If you are using an aftermarket/reloaded cartridge and the cartridge chip is defective. First try a new cartridge. The best bet is a new OEM cartridge, run the deep cleaning utility 3 times. The nozzle may be clogged and this will clean the nozzle.
Aftermarket/reloaded cartridges ink do not always meet the specifications for the printers that use the finer inks.
Let me know if this works for you. Thanks.
Mar 07, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Cartridge problem.
Is it a dell cartridge or a different brand altogether?
If it is a dell brand it could be defective. There is a chip that determines if it is the correct brand and sometimes that breaks.
If you have already changed the cartridge to a brand new dell brand one and it is still happening, then I would suspect the sensor is bad. Probably cheaper to replace the entire printer than to send it in for warranty replacement if it still has warranty.
Jul 29, 2009 | Dell 924 All-in-One InkJet Printer
Won't accept new ink cartridge
Look inside where the ink goes, there is a spring on the right side, if it comes out of place it can cut the ribbon cable at the rear. If thats the case, you need a new printer.
Jul 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Have just replaced the colour ink but getting message to replace. It doesn't recognise there is one in.
If you used a generic brand cartridge, you might try an original HP replacement. I have had many HP printers for service that don't work well with the remanufactured cartridges.
If the new cartridge is an HP, try exchanging it as defective where you purchased it. You probably got a defective cartridge. (Hey, it happens occasionally!)
Apr 27, 2009 | HP Officejet 5610 All-In-One InkJet...
Issue printing in black ink after changing to new catridge, other colors prints fine except black -Venu
There is a very good chance that your brand new cartridge is defective. If you have another cartridge put that in and see what happens. If the second cartridge works and the first didn't then it is for sure a defective cartridge.
There is nothing on Brother's website referring to this situation, so I would bet that it is a defective cartridge.
May 01, 2008 | Brother MFC 420CN All-In-One InkJet...
Color cartridge
that is most proberly a defective cartridge packermary you need to try another cartridge if it works then return the defective cartridge or else try cleaning the head on the cartridge by using alcohol or spirits and wiping the pins on the cartridge head & the coper part of the cartridge.
Apr 18, 2008 | Dell Inkjet 720 Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
254 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
