Question about Sharp AR-5316 Advanced Digital Imager Copier
Helpfull WHEN I PUT MY COPIER ON IT DISPLAY H4
  • 1 more comment
  • omarnayfeh Dec 27, 2007
    please...what it meens p?our machine hasn't P key
  • Jafta Jan 15, 2008
    Have the same problem. Checked the lamp , themoster and themofuse and all is fine but still got the code. none of the codes given fixes the problem.
  • Marine11 Jan 21, 2008
    Got the same problem. Can some one help me out?
  • Sharp Master
  • 1,113 Answers
#, *, c, * very quick then 14 print is reset, if it comes back after reset then it needs fuser/fuser lamp.
Posted on Dec 26, 2007
  • 5 more comments
  • Soulvisitor
    Soulvisitor Dec 26, 2007
    P, *,C, * 14 very quick then 14 print is reset, if it comes back after reset then it needs fuser/fuser lamp.
    u try remember 20 brands service codes
  • Soulvisitor
    h4 is heater lamp failure but can be triggered sometimes by surge, hence reset first.
  • Soulvisitor
    Soulvisitor Dec 27, 2007
    Do you have the #???
    P is Pause or interrupt
    C is Clear/Cancel
    Change rating!
  • Soulvisitor
    MUST BE DONE FAST!
    all buttons are near keypad!
    sharp has so many codes oldest CROP and CRUD. Current P*C*, and #,*,C,* then 14,...... my fingers do it easier than typing it....but none will fix your machine unless this fault was triggered by a power surge on appliances line, it is telling us that the fuser lamp/fuser is Kapoot!/GONE/FRIED/CHECKEDOUT.
  • Soulvisitor
    if you want any more input then fix the rating very unappricative
  • Soulvisitor
    Soulvisitor Dec 28, 2007
    Ok have looked in the service manual for you and have the correct code for your model but will refraim from posting untill unappricative rating is removed, back to you.
  • Soulvisitor
    Soulvisitor Jan 19, 2008
    Jafta the real code is
    # interupt c interupt 14
Display panel h4 code any clues?
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time.
It is usually a blown heater element.
You will need a technician to repair this.
May 01, 2010 | Sharp AR-235 Copier
Copier flashing "H4" code
Hello sir;Follow these steps within 4 seconds; press 'clear', "exposure" ,"clear" "exposure" then enter 14 hit print, should be OK.
Jan 30, 2010 | Sharp AL 1631 Copier
Irc2105
There is no such error 'E215-0000' in ar 5320, for H4 use "#, Interrupt, C, interrupt. Display goes off, Enter 14, Press Print key.
Apr 08, 2009 | Sharp AR-5320 Black and White Copier
Call for service H4-00
please do the following : press #, interrupt, C, interrupt when display goes off enter 14 and pess print button
Jan 23, 2009 | Toshiba e-Studio162D Copier
Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
Dec 17, 2008 | Sharp SF 2020 Copier
Please Help
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
MY SHARP AR5316 DISPLAY H4 WHEN I PUT IT ON
Here is the process
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Dec 11, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
83 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
