Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Hard drive crash
I hear a weird sound from my WD hard drive. The system does not boot. I tried going into the CMOS, but it hangs. Need to recover the data. need solution.
  • 95 Answers
What kind of sound is that? Anyway it's not a good symptom.
Check out this page with sounds hard drives make: http://datacent.com/hard_drive_sounds.php
Does it sound like yours?
Hope it helps.
Posted on Nov 07, 2008
  • 70 Answers
Your hard drive has crashed but here is what you can probably try. Take off the hard drive. Put it into another system (a friend's computer or something) as secondary drive. See if it gets detected in the BIOS. If it does, you can try and run a application like Recover my files to try and salvage your data. Hope this helps.
Posted on Dec 26, 2007
I can't access my wd external hard disk (passport )through (my computer) i can see it using windows disk management as unallocated partition...when right clicking..no options are active but properties
Hello
Have you tried accessing the hard drive on another computer?
Have you tried using a different USB cable?
Was the hard drive dropped or moved while it was plugged in?
Check the WD Site if you hard drive has warranty.
I hope this solves your problem and please reply if you need more help.
May 11, 2011 | Western Digital Passport WDXML800UE...
Tip
How to repair hard drive
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Operating software installation or build CD</span> </li> <li> <span>Boot-up disc</span> </li> <li> <span>System restore CD</span> </li> <li> <span>Backup tape</span> </li></ul> <ol> <li> Look for tell-tale signs that your computer is about to crash or fail. Extreme slowness, repeated blue screen and noise or clicking are sometimes signs that your computer hard drive is about to crash. When you hear the sound of clicking, scraping or grinding, immediately turn off or shut down your computer. Doing so will prevent any loss of data.<br /> </li> <li> Power down and then power up. Sometimes, hard drive crashes can be easily recovered by doing a power shutdown of the computer. Then, after waiting for a couple of minutes, power it back up again. The initial hard drive crash may not be too serious, but if it happens often, start performing a full system backup, if you haven't been doing so, to be able to recover your data should the inevitable happen.<br /> </li> <li> <span> <a><img src="repair-hard-drive-crashes-1.3-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.3-800X800.jpg'); }); PC cable or component connection </span> Ensure that your hard drive and other internal components are seated properly. If Steps 1 and 2 do not work, you may need to open your computer's CPU to check on some of the drive connections. Sometimes connections get dislodged, especially if you move your computer box often. The symptom will manifest as if the hard drive has crashed, giving you a "disk error" when you try to boot up your computer. First, turn off your computer and unplug it. Then remove the case of your computer box. Press on each connector to connect it properly. Put the cover back again, plug the computer and power it back up.<br /> </li> <li> <span> <a><img src="repair-hard-drive-crashes-1.4-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.4-800X800.jpg'); }); Boot from CD drive with a boot disc </span> Insert your boot disc and try to boot up your computer using the disc. Once you are able to do so, you can reinstall your operating system. After installing your software, proceed to perform data recovery using your ghost CD or backup.<br /> </li> <li> Use an emergency repair disc to get your computer to work again. Then restore from the last known good configuration.<br /> </li> <li> Reinstall your operating system using the installation or system restore CD that came with your computer when you first purchased it. It will take you through a series of steps that include formatting your hard drive, which will then erase your data. Do this as a last resort.<br /> </li> <li> Recover your data by using a restore and recovery software or using your most recent backup after you have reinstalled the operating system in the previous step.<br /> </li> <li> Reinstall your applications that did not come with your computer when you bought it. Some examples would be Adobe Photoshop, anti-virus software and movie-making software.<br /> </li></ol> jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); <span>Tips & Warnings</span> <ul> <li> Call technical support if you are unsure of what to do. They can walk you through the important steps. You can also take your computer to a PC technician who, for a fee, will do a system restore and data recovery for you.</li> <li> Make it a habit, even if your computer is healthy, to do a complete backup so your important data will not be lost.</li> <li> Never attempt to open your computer without first powering it off to avoid being electrocuted.</li> <li> Do not open your hard drive case; the components are so sensitive that even a single speck of dust may erase your data.</li></ul>
on Dec 23, 2010 | Computers & Internet
My hd crashed. how can i save the data?
You can try putting it in the freezer. Sounds crazy but it often works. One thing you need to be sure of is to copy your data off as fast as possible, so have another hard drive ready to copy to. It is not a permenant fix and your external HDD should not be used after you retrieve the data.
http://googlesystem.blogspot.com/2006/04/how-to-recover-data-from-hard-drive.html
Apr 05, 2011 | Western Digital Elements powered by WD 320...
Hey, Im a big fan of WD, but i have a small problem which need to be help from you people. I was using WD1600JS from long time with lot of good data storing in that. But unluckily my HDD got crashed n...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Mar 15, 2011 | Western Digital WD Caviar Blue WD1600AAJS...
My WD My Book Essential 1TB External is not showing up on 'My Computer'. It was working perfectly in the morning, then when I rebooted my machine it no longer showed up.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
Jan 03, 2011 | Western Digital My Book Essential 1TB...
My computer hangs when I start it up until I remove the WD 320 GB External USB connection - then it will restart ok. I have to then reconnect the hd. - what can I do about this?
It sounds like it is trying to boot from the external drive, go into the BIOS settings and disable boot from external device and see if that cures it.
Mar 30, 2010 | Western Digital Elements powered by WD 320...
Lenovo 3000 N100 0689 hangs at boot up .
If you have a rescue disk or a System Disk that came with the laptop, use that and try to recover the system....boot using that and do a recovery....
or
Else you may have to re-install the WinOS
Mar 04, 2010 | Lenovo 3000 N100 0689 Notebook
Ave tried to use the recover disk 4 times now, and
If you reinstalled the Operating System and are still getting errors then it is a hardware issue.
From what you describe it sounds like your hard drive is failing. A failing hard drive will "lose" files out of nowhere and cause many "weird" errors because the lost files are usually system files needed for Windows.
Feb 11, 2010 | Toshiba Satellite M55-S3512 Notebook
My hardrive is making weird sounds, it's brand new. What does this mean?
If you harddrive is making weird sounds the head might be damaged. Contact the company it should have a waranty.
Jul 01, 2009 | LaCie 301262 1TB Spare Drive for Biggest...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
154 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
