GE Spacemaker Washer and Dryer Electric Laundry Center - White
Problem for GE Spacemaker Washer and Dryer Electric Laundry Center -...
Washing machine will not drain
By gdboone2 on Oct 11, 2009
washing machine will not drain
Best Solution
posted on Oct 11, 2009
Very Helpful)
ibaara
Rank: Guru
Rating: 93%, 23 votes
Most likely the solenoid valve is clogged. Remove the water with wet vacuum machine. Remove the front panel (two screws on bottom). The valve will be on lower left side. Two hoses are connected to it. You have to disconnect them (there is a lot of water in them). Make sure the vacuum machine is ON. Check the valve with your finger. Vacuum both hoses. Good luck.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
GodBlessU
Rank: Wiz  Washers & Dryers  Expert
Rating: 85%, 146 votes
Hi
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting Fixya.com
Was this helpful?
Yes
No
Popular Solutions for GE Spacemaker Washer and Dryer
Questions and Unsolved Problems for GE Spacemaker Washer and Dryer
Do you recommend GE Spacemaker Washer and Dryer Electric Laundry Center - White?
Answer
Answer
spacemaker washer agitates, then drains and keeps draining and will not spin
Answer
The washer fills with water, but will not switch to the next cycle.
Answer
water drain leak. I think the hose may be clogged but don't know if I need special tool/technique to... (More)
Answer
It is a GE Spacemaker Model WSM2400LEBWH W/D combo. When Dryer timer is in off position, buzzer... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Spacemaker Washer and Dryer...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
