Question about Motorola Mobility RAZR V3
The screen and keypad split apart!!!! please help!!!!
When i was using my phone i accidentaly dropped it and something in the side of the screen popped out!!! then the screen and keypad was apart!!! when i checked inside a paper-like thingyleft side was cut!!! how can i fix it or can i still fix it?
    Scholar:
  • 111 Answers
You need to provide more information for us to determine what was cut, is it still working? If it's not the keypad pad then you should be able to use it, if not it may need to be repaired.
Hope that helps
Posted on Dec 26, 2007
I have a samsung galaxy google cell phone for 7 weeks now and dropped it from my waist height to the floor.Now the phone will not work. the screen is not broken, sim card and battery is in tight, battery...
I used to repair thease and manny other brand phones, the problems is a lose conenction with the internal ribbon cable.
their are Lcd cables and Digitizer cables that connect the touch screen to the lcd. it;s an overlay for the most p[art. the idea is that the phone dropped and the screen cable probably came lose. this is more or likely a simple case of plugging the cable back in but id get some details on that phone so you know how to take apart and put back together. hints and tips like pressing on the side to help relieve pressure and the issues with the cables getting broken off due to pulling to hard are very real so please do not attempt if you are not confident in your abilities. their fairly cheap to replace these days.
Try this site out for more help.
Bellow is instructions for the HTC-T Mobile G1 Google cell phone But the idea is very similar. just Google your phone model if this is not the right one. the ldc cables are very thin and disconnect under any shock these day's
Here
If you need more help please just clarify the make and model of your phone and we will see if we can get you more detailed instructions.
Feb 14, 2011 | Cell Phones
Looking to replace speakers and don't know how to take apart
browse to the internet for motorola razor v3 dismantling
Oct 11, 2010 | Motorola Mobility RAZR V3
I cannot turn off the key bleeping
If you use your volume keys on the side of the phone, press the down one and volume level thing shows on the screen, in a circle from 0-7. pick the level of sound you want 0 is silent. or if you go into the settings menu on your keypad and go to the phone settings you will find keypad tones in there aswell where can also turn it off. hope that helps !
Jan 16, 2010 | Samsung SGH-S5230 Cell Phone
Lg dare touchscreen not working all of a sudden.
possible cause, you may be accidentaly drop it, or seat on it...
first if it has it manual keypad, then use it and try to set on factory setting default.
Default security code..12345 or 1234
see if it works but beware , all your personal profile might erase, but before doing it try to remove the sim card and memory card.
if it still not work then bring it to cellphone technician, there is a possibility that the flex (tape wire type) or the black crystal(small IC part)migh be damaged
Oct 29, 2009 | LG Dare VX9700 Cell Phone
How do i change the housing on my 6500 slide mobile
You need a T5 screwdriver and a new housing... Use an Original housing, copies dont usually fit right... 1, Remove Back cover and Battery. 2, Remove 4 T5 screws at the back of the phone, run your fingernail/opening tool around the housing and it should come away a little, dont pull it apart as there are 2 ribbons one for the Screen the other for the keypad. 3, Turn the phone over and run your fingernail under the keypad. 4, Carefully take the bottom half away with the phones PCB still in the bottom housing, using a flat screwdriver carefully lift off the two Ribbons 5, You can then remove the keypad from the top part of the phone, this is stuck on by double sided tape pull downwards, there are 2 spring loaded pieces on each side. 6, Remove the 4 T5 screws, 2 under where the Keypad was and 2 at the top 7, Again using your fingernail or a opening tool run around the edge and the screen part should come apart, dont damage the ribbon You now have the phone apart take out the bits and change what you like :)
Jun 10, 2009 | Nokia 6500 Slide Cellular Phone
Keypad
the only thing that you can do is to change the hall keypad.
because if you take off one button, the hall keypad is going to get messed up
Feb 14, 2008 | Samsung SGH-T519 Cellular Phone
Blank Screen!
Bring it back for repair.
Feb 04, 2007 | Samsung SCH-a670
Phone dropped in Water
may be is time for a new phone, sorry about that!
Dec 03, 2006 | Samsung SGH-p207
Motorola Mobility RAZR V3 Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
