Home | Toshiba | 27AF41 27" TV | Horizontal white line
Toshiba 27AF41 27" TV
Problem for Toshiba 27AF41 27" TV
By pilboudo on Oct 11, 2009
horizontal white line
Comments:
Oct 11, 2009
- Could you specify the description of this IC?
Solution #1
posted on Oct 11, 2009
Not Rated)
maatmartin7
Rank: Guru
Rating: 91%, 54 votes
The vertical IC needs resoldered and the caps in the immediate area checked and replaced. This is a good starrt for repair.
Comments:
Oct 12, 2009
- It could be one of two types i believe in this case. Idon't think the Ic is bad...Look for either IC# starting with the letters TDA or LA78 series. It is located on a heatsink to draw heat from the IC. So I would suggest if you can find the 7 pin {TDA} IC...look for rings around the pins..this must be resoldered. The LA78 series has 7, 9 or 13 pins and used in older TVs.
Oct 13, 2009
- Correction, the TDA vertical IC will have five pins.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 27AF41 27" TV
Questions and Unsolved Problems for Toshiba 27AF41 27" TV
Do you recommend Toshiba 27AF41 27" TV?
Answer
Answer
Tv was givin to me with no power button and a remote, I told giver that I I have comcast remote.... (More)
Answer
My television keeps having a flashing red light when I try to tun it on. Is there anyway to turn it... (More)
Answer
The tv won't turn on when I press the poswer button. The red light blinks, but won't turn off when I... (More)
Answer
The tv won't turn on when I press the power button. The red light blinks, but won't turn off when I... (More)
Answer
cant gat my older rca direct tv remote to operate my toshiba model 27af41 tv
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 27AF41 27" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
