Question about HP ScanJet 3690 Flatbed Scanner
Scanner out put is yellow and red what is the problum
    Genius:
  • 2,985 Answers
CCD failure probably.
Reload softeware to be sure.
If it is still the same replace scanner there is no repair option
Posted on Dec 26, 2007
Line on copy
1) clean scanner's glass
2) check drum unit or print heads
Nov 12, 2014 | Office Equipment & Supplies
I need to know how to wire a led scanner to an avital 5303. The light has a red pos, black neg, and yellow that says brake. i want it to come on when the alarm is activated
Forget the yellow wire. Its for wiring WITHOUT an alarm. Connect the red to a fused 12 volt and the black to the orange "ground when armed" of the Avital 5303.
Jan 21, 2013 | AviStart 5303 2-Way Security / Remote...
Scanner error 5
Follow these steps:
1) Switch off the printer
2) Open the upper cover where the scanner is
3) Clean the white stripe, which is on top of the scanner "home"
4) Open the right side cover - it has two screws that hold it in place
5) Switch on the printer
6) On start up, put the upper cover back on the scanner
7) Then the scanner starts moving, unplug and plug back in several times the green, blue, yellow, red connector which is up on the upper left side of the metal cover
8) Then the error should go away
Good Luck
Nov 09, 2011 | HP Office Equipment & Supplies
VGA problum display problum
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don
Mar 25, 2011 | Intel D845GVSR Motherboard
My problum is red colour not appear in printing this is convert to yellow how solve
First of all check your ink cartridges after selecting the maintenance program .If bad replace and make a test print.
had a head cleaning done within the program. If there is no improvement remove printer, reinstall and check once again.
If not the printer head can be faulty .
Sep 14, 2010 | Office Equipment & Supplies
Sony wega #KDF-55-WF-655 won't turn on: goes to standby mode
don't wory sir , may i help you .
this is a not mager problum but sum times technicean is parsnal baneefits besness and fast money making this rongh dignosis and canfused to castamer so don't wory ...
[1] problum is in side tv set in out put voltage form EHT becose your tv is red and green light is ok then SMPS is ok
pls. check with tv techicean and follow sum tips
* voltage check From EHT out put and canacting spear.
* H- out put tangester and cancting sperar
* H out put tarngester base tarminal voltage check if ok then 100% problum is EHT or canacting spaer so don't wory all spear is not very expancive pls.find Best tech.and solve this problum Esely
best of luck...
Jan 30, 2010 | Toshiba CZ36V51 36" TV
WHEN I TURN ON TV I GET A RED SCREEN WITH HORIZONTIAL LINES STAYS ON FOR 10-15 SECONDS THEN TURNS OFF STAND BY LIGHT BLINKS 7 TIMES SORRY THIS IS A SONY KV35V65 TV
this is a red retras line problum
[1] red cathoud video amp. trangester is sort or dry canaction
[2] red cathoud is sorting with filament terminal is in side pictur tube
so pls. cont. your nr. tv. tech. solve this problum. it is not very expancive
* this is a coman problum if your tv set is 7 to 8 year old.
Nov 10, 2009 | Sony KV-32V65 TV
Hp inkjet 3500 prints red as yellow
how do i get the printer to read that i have put in a new transfer kit.
May 06, 2008 | HP Color LaserJet 3500 Printer
HP ScanJet 3690 Flatbed Scanner Logo
118 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
