Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Green dots on screen
Green dots shadowing around things on the screen
  • wver Jul 24, 2008
    Problem is not the same but similar, has flickering green and purple pixels say around clouds in a movie or game, not constant just flickering. if I unplug the tv for about 30 minutes or have it off for 30 minutes or so and turn it back on the symptom is gone for about 10 minutes. I've reconnected the cables and seems to be happening on all signal sources, HDMI, Component, VGA, and RCA. any help would be good. Oh i do have an extended warranty on the TV from the store I purchased it through.
  • 69 Answers
Green dots on a LCD screen are burnt out pixels and unfortunately are incurable other than having the TV serviced at a high price. One of the reasons it is a good idea to get a warranty on these types of TVs is primarily due to this very problem....burnt out pixels.
Posted on Dec 26, 2007
Why do I have a green dotted line all the way around my screen and nothing will change when you touch it only the dotted line
green dotted line shows your current position and it can not be changed as its your position and changed as you walk
Oct 28, 2015 | GPS
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
Green shadow or static lines(dots) all over screen
Problem sounds like ignition noise. Depending on the condition of applainces and electrical distribtion box (Fused/circuit breakers) on the premises. Could also be entering through outside source. The best way to find out if this actually causing your problem is to take a portable radio and tune around 550mhz on the AM band. If you hear a buzz or crackle tune radio to the loudest hum or buzz, then walk around aiming towards the more signal or louder it gets until you find the source. Hope this helps.
Jan 11, 2009 | Vizio L32 32 in. LCD HDTV
Purple and green strip/shadow around all the images and at the bottom
Either a bad optical block or possibly a bad LVDS cable, you need a qualified tech to know for sure
Sep 19, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Kolin PT-501 LCD/LCOS HDTV, rear projection TV
Well i really do not know what that is but i do have a thought it could be a bad connector and if you want i have the same tv for sale for $300 shipped just for parts the problem with my pt501 was the screen turned colors but the lamp is in excellent shape and so is the lcos screen the ownly thing that does not work is the main board (ciruit board) i will send you the hole thing for just 300$ shipped if you'd like email me back
Jun 29, 2008 | Olevia Kolin DLT2711M 27 in. LCD...
Picture off and shadow of back images.
Hi Grim159
I've had this once on a Epson Projector and the only way I could this right was by replacing the Mainboard.
Hope this is of help.
Apr 22, 2008 | Philips ProScreen 4600 Impact Multimedia...
Green shadows surrounding bright whites
finally a consumer that gives us plenty of info :)
sounds like an overdriven green tube, the only thing you can try is to find the G2/Focus block assembly, either behind front speaker grill or remove back of set and look for a black box approximately 5"X5" , this box will have 6 philips type adjustment screws(plastic) 3 are for focus, do NOT adjust these,
the other 3 are marked "screen" the center screen adjustment screw is for green, turn it VERY slowly counterclockwise while the set is running and pray that your problem dis-appears, be advised that this is a HIGH VOLTAGE device so one hand in your back pocket the other hand turns the screwdriver, if the problem does not go away you have a poor green tube, good luck, sorry I can`t give you the exact location of the G2/Focus block, manufacturers move them to different places every year.
Nov 29, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Panasonic Color Rings
It sounds like you have a warped shadow mask in your picture tube if your set uses a picture tube. A shadow mask is like a screen wire that lets the three color guns shoot electrons to their respective phosphor dot on the screen to produce the three primary colors which are mixed properly to produce the scene that is being shown. In other words you have a bad picture tube. Stargazer
Aug 12, 2007 | Panasonic CT-27SF37 27" TV
Problem in Screen display
Hi, J ! You didn't say how old you set is, but to me it sounds like you may have a warped shadow mask in you picture tube. A shadow mask could be compared to a piece of screen wire. It's function is to make the electron "beams" from the three electron guns strike the proper phosphor dot to produce the proper color- red-green-or blue. If this is the case the picture tube would requie replacement. Stargazer
Jan 09, 2007 | Sony KV-21CT1 21" TV
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
1,538 people viewed this question
Jerry Greenberg
Jerry Greenberg
