Question about Sub-Zero 680 / F
Refrig lights go on and off intermittently when opening and closing refrig door
Sub Zero model 642
    Problem Solver:
  • 7 Answers
Check door light switch with ohmmeter. Check for melted insulation near light "terminator". Look for wiring diagram in ziplock behind compressor grille. Second switch at door turns compressor off when door opened. I had these problems with a 695 which I would assume is probably similar in design.
Posted on Jun 01, 2008
  • 173 Answers
Check light bulb as it can be loose. Door light has a bad contact
Posted on May 22, 2014
How do I change the door panels on a model 642/F
If you have an overlay door, by removing the door handles, should be about 6-8 screws located when you open the door look at the handle, you should see these screws run top to bottom.
I hope this helps.
Oct 12, 2013 | Sub-Zero 642
LCD panel and lights not working
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Mar 26, 2012 | Sub-Zero 642
Turn off code for sub zero refrig 642
Hi Dave,
On your control panel, do you have a (bell) logo? If so, press and hold that button unit the code disappears, it could take ten seconds or so, you should hear a beep. If not, turn the unit off for about 1-2 minutes by the control panel on/off switch, then when you turn it back on it should not re-appear. It depends on the model and version software in the unit on how to remove the service light and error codes. But if you continue to receive error codes you will need to have the unit looked at by a certified technician to prevent bigger problems down the road. I am a certified technician and willing to lead a hand when possible. You code 24 is a defrost over heat fault, which can happen from time to time, every-time I found this code I could never find an error in the system or defrost hardware, when I cleared the code, it never appeared again. I hope this helps.
Nov 06, 2011 | Sub-Zero 642
I have sub zero 642 and my techinician says that I need a ice make valve replacement. He says it costs $495, does that seem accurate?
Sub-Zero a hallowed name in refrigeration, and the 642 side-by-side refrigerator/freezer unit is a landmark Yeah, it's that impressive. Dual refrigeration uses two compressors and three evaporators, I can tell you to never expect less than $300 for calling anyone to your home!
Aug 10, 2011 | Sub-Zero 642
I have a ten yr. old Sub Zero model 642. The
maybe a re-gas will last another ten years...if the leak is that small a re-gas will probably last it days out....ask the service man to re-gas it so the food does not spoil until you can save up for replacement...then just see how it goes.
Jul 21, 2010 | Sub-Zero 690 Side by Side Refrigerator
Problem openning door
when you close the door a reverse cycle fan sucks all the waisted air the fridge has just been exposed to out of the unit so it creates a good seal around the door rubbers this is perfectly normal .
please rate ..
Jul 04, 2010 | Sub-Zero 642
My sub zero 642 just starting making a humming
It is your evaporator fan. When the door opens power is cut to the fan motor.
Apr 29, 2010 | Sub-Zero 642
My Sub Zero 642 is freezing my fruits and vegetables. I have not changed the temperature settings. What's up? I did unplug the unit to reset it but it keeps having the same problem.
Usually a bad thermostat, but it can be a freon system problem, or a problem with your evaporator fan motor. These are problems that a good Sub Zero technician needs to repair, especially if you have a system problem, since a system problem is under a 6 to 12 year warrantee. Make sure that the company you call is a Sub-Zero warrantee company. Good Luck, Appliance Specialists
Jan 19, 2010 | Sub-Zero 642
I have a 642/0 side by side sub zero. Although
Has the ambient temp around the unit been going up? Depending on what refrigerant you have here the pressure temp relationship will change in the system, also when you add foodstuff, and again when you open the door.
Jun 29, 2009 | Refrigerators
Refrigerators Logo
237 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
