Question about Nokia 6288 Cellular Phone
Cleaning problem 6288
Please help with an issue that i have with my 6288.it's collectiing tons of dust behind the glass protecting the screen is it possible to take it off and clean it by myself or i have to pay money for service?
    Problem Solver:
  • 6 Answers
Yes you can do this yourself but you may need special tools they are called t drivers can be bought at sears for around 10 buks or so just be carefull when takeing the phone apart
Posted on Dec 26, 2007
How do I get to and clean screen of a Hitachi 60fx20b
honestly you will probably cause more issues than you will solve. If you separate the layers it will allow dust to get in and that will show up worse than water. If you are sure you can do it, then the front needs to come off. but be really careful.
Sep 07, 2015 | Hitachi Televison & Video
Monitor cleaning & hard glass protective layer removal
Of all the LCD/LED monitors I have used, I have not seen one that has a removable glass face.
Nov 10, 2013 | AOC International 23" Wide Lcd 1920x1080...
I have a Mitsubishi 60"
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
Sep 05, 2011 | Philips Magnavox 51MP392H Rear Projection...
Smudge, streaks, rays imac 24 monitor clean inside LCD
Yep, you can clean the LCD and the inside of the glass, but you will need two suction cups for glass. The ones for picking up window glass work. Lay the computer on its back. Place the suction cups at the upper corners and pull straight away from the table. The glass is held on by magnets and may have tabs at the bottom, so once the magnets are loose you may have to lift the glass away from the bottom edge. Be careful, it isn't safety glass and can break if dropped. The hardest part is keeping dust from getting between the screen and the glass during reassembly. Try working in a dust-free environment. I use two micro-fiber cloths, one with screen cleaner and one dry. You can't believe how much static builds up on the inside of the glass. It just sucks in dust. Don't wear fleece or you'll end up with fuzz as well. Stand your iMac up to reinstall. Clean the outside of the glass so you can see any dust on the inside. Place the bottom in place first. As you prepare to move the top into place, have light behind and above you and view the glass with the black screen behind. You can see most of the dust that way. Good luck.
Apr 23, 2010 | Apple iMac 24" Desktop
Ceiling leaked into the plasma tv now has a black streak . can this be fixed
Hi my name is Eric,
I hope I can help you with your issue ,
Well you could take it apart and see, most plasmas have a glass front with a screen behind it. If you take the screen out you could clean the glass if thats where the black is. This job is about 2 hours on most plasmas.
If your TV is an LCD then there usually is no glass, tough the front and check. in that case you'd need a new screen
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 01, 2009 | Sony KDL-40S3000 40 in. LCD HDTV
Looks like dust behind front glass on phillips 46pp8621
The only way to remove the dust and or spider webs from that area is to remove the front bezel assembly and separate the protection screen, it's better to leave a svc. co. do this because the two screens behind that are very expensive. Hope this helps..
Feb 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
How do I clean my SOYO plasma computer screen?
Hey lue6,
In order to clean your plasma screen, it's generally recommended to use a dry, soft and lint-free (microfiber) cloth to gently brush dust away. You'll want to avoid using commercial cleaners such as Windex or Pledge, even if they are intended for glass surfaces. Abrasive chemicals in such cleaners have been known to cause corrosion of the anti-glare protection on some screens. Remember to avoid putting any kind of pressure on the screen itself while cleaning, as pressing against the glass may cause damage to components beneath (and within) the screen.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 25, 2008 | Computers & Internet
Dust behind screen
Wait for some minutes i am uploading vidio for that on rapidshare and will post here it's links after few minutes.
Jan 10, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Nokia 6288 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
