checked under the fridge at the value and water comes out, but then stops, i hit the water again on...
(More)
CHECKED UNDER THE FRIDGE AT THE VALUE AND WATER COMES OUT, BUT THEN STOPS, I HIT THE WATER AGAIN ON THE DOOR AND IT COMES OUT FROM THE BOTTOM AND THEN STOPS. I TOOK OFF THE FILTER AND NO WATER COMES OUT FROM THERE WHEN I PUSH THE WATER ON THE DOOR. WHEN I PUSH ON THE DOOR IT SOUNDS THE SAME AS IF I WAS GETTING WATER, BUT NO WATER. I HAVE EVEN LOWERED THE TEMP TO THAW OUT THE FRIDGE AND IT STILL HAS NOT WORKED. PLEASE HELP
top oven thermostat fault and cooling fan for switchs seens to run on to long the oven is model no...
(More)
top oven thermostat fault and cooling fan for switchs seens to run on to long the oven is model no bd 81 is it a specialist repair or can it be d i y
my hot point refr is making noise i think it is the compressor what should is a compressor...
(More)
my hot point refr is making noise i think it is the compressor what should is a compressor replacement somthing i can do myself
