Atari Rollercoaster Tycoon 3 (Platinum) for Windows Logo
Posted on Oct 11, 2009
Deos this work on xp - Atari Rollercoaster Tycoon 3 (Platinum) for Windows
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Oct 14, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
Helped
8235
Points
30
If you still have the box the cd came in, it should list what operating systems it works with on the buttom of the back cover of the cd box.
I have a sony vlp vw10ht and the component red just recently seems to have faded out or stopped working. Is this a repairable situation?
Hello Dennis, please indicate, which device is connected to your Sony projector, indicate brand, model and type of device (DVD, VCR or other)
This projector has 3 Video inputs, two color inputs separately (Component Video) and one Composite video
I suggest you replace the cable between the projector and the image source and check if the problem is corrected, if you do not have another cable, try to connect some video signal to the Composite video input and see if it is missing the red color, If so, you would have a problem in the projector, if it looks good, the cable would be wrong
I hope you manage to solve the problem, comment the results
Greetings Franco Dosil
Hola Dennis, por favor indica, que aparato esta conectado a tu proyector Sony, indica marca, modelo y tipo de aparato(DVD, VCR u otro)
Este proyector tiene 3 entradas de V?deo, dos entradas de color por separado (V?deo por Componentes) y una de v?deo Compuesto
Te sugiero que reemplaces el cable entre el proyector y la fuente de imagen y compruebes si se corrige el problema, si no cuentas con otro cable, prueba conectar alguna se?al de v?deo a la entrada de V?deo compuesto y observa si esta faltando el color rojo, si es as?, tendr?as un problema en el proyector, si se ve bien, estar?a mal el cable
Espero que logres resolver el problema, comenta los resultados
Saludos Franco Dosil
https://www.projectorcentral.com/pdf/projector_manual_623.pdf
tip
C?mo limpiar de forma segura a un Jefe de cintas de v?deo
<span><span><span>Si</span> <span>usted no est&aacute;</span> <span>recibiendo</span> <span>v&iacute;deo</span> <span>desde</span> <span>un VCR</span><span>,</span> <span>videoc&aacute;mara</span> <span>de 8 mm</span><span>,</span> <span>o</span> <span>c&aacute;mara de v&iacute;deo</span> <span>digital</span> <span>grabadora de v&iacute;deo</span><span>, pero</span> <span>de audio</span><span>obtener</span><span>, haga lo</span> <span>siguiente</span><span>:</span></span></span> <span><span><span><span>1</span><span>.</span> <span>Utilice</span> <span>una cinta grabada de</span> <span>nuevo</span> <span>-</span> <span>a</span> <span>la derecha</span> <span>del</span> <span>paquete</span> <span>e insertarla</span> <span>en</span> <span>la</span> <span>unidad.</span><br /><span>2</span><span>.</span> <span>Lleve a cabo</span> <span>un registro</span> <span>en la</span> <span>cinta</span> <span>-</span> <span>la puso</span> <span>a</span> <span>hacer</span> <span>un registro (</span><span>no</span> <span>la reproducci&oacute;n</span><span>)</span><span>.</span><br /><span>3</span><span>.</span> <span>Deje que se</span> <span>completa</span> <span>a trav&eacute;s de</span> <span>toda la cinta</span> <span>sin parar</span><span>.</span><br /><span>4</span><span>.</span> <span>Al</span> <span>terminar</span> <span>-</span> <span>le permiten</span> <span>rebobinar</span><span>.</span><br /><span>5</span><span>.</span> <span>Inserte</span> <span>una</span> <span>conocida</span> <span>cinta</span> <span>pregrabada</span> <span>buena</span> <span>y el juego</span> <span>-</span><span>observar</span> <span>la imagen</span><span>.</span> <span>Si es</span> <span>bueno</span><span>,</span> <span>entonces</span> <span>la</span> <span>cabeza</span> <span>estaba</span> <span>sucia</span><span>y</span> <span>est&aacute; limpio</span> <span>ahora</span><span>.</span><br /><span>Usted</span> <span>puede llevar a cabo</span> <span>lo anterior</span> <span>cuantas veces sea necesario</span><span>sin ning&uacute;n tipo de</span> <span>da&ntilde;os en el</span> <span>aparato</span><span>.</span></span></span></span>
on Dec 13, 2010 • Televison & Video
How to connect sanyo ASX_3000 swoofer to a 50 in flat screen Panasonic plasma tv
Hi Sherry, if you have the complete ASX_3000 Subwoofer, that is the VHS player + DVD player, the Subwoffer speaker and the 5 speakers, you have to connect the audio and video output that are on the rear panel of the player. VHS + DVD player, to the corresponding input on your Panasonic Plasma
You have three video output options, Composite Video (Yellow Connector), Component Video (Green, Blue and Red Connectors) or S-Video, 4-pin connector
I was looking for the Sanyo ASX_3000 user manual and I do not get it, instead, I sent you the Sanyo ASX_3500 link, which is similar to the effects of the connections and you can see what I mentioned before.
I hope you can enjoy your Sanyo on your Panasonic Plasma TV
Hola Sherry, si tu tienes el ASX_3000 Subwoofer completo, o sea el equipo reproductor de VHS+ reproductor de DVD, el bafle Subwoffer y los 5 bafles, tienes que conectar la salida de audio y v?deo que se encuentran en el panel posterior del equipo reproductor de VHS+ reproductor de DVD, a la entrada correspondiente en tu Plasma Panasonic
Tienes tres opciones de salida de v?deo, V?deo Compuesto (Conector Amarillo), V?deo por Componentes (Conectores Verde, Azul y Rojo) o S-V?deo, conector de 4 pines
Estuve buscando el manual de usuario del Sanyo ASX_3000 y no lo consigo, en cambio, te env?o el link del Sanyo ASX_3500, que es similar a los efectos de las conexiones y puedas observar ah? lo que anteriormente te comente
Espero que puedas disfrutar de tu Sanyo en tu TV Plasma Panasonic
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Sanyo-DWM-3500-Owners-Manual.pdf
What deos "de" mean on whirlpool washing machine?
Maybe. Door not closed that's what mine means when I see de
Timex w-215 replacement watch band
Cua hang dongho Galle Watch chuyen phan phoi cac hang dongho deo tay nam va nu nhap khau tu thuy sy va nhat ban...,Cua hang Galle Watch chuyen buon ban cac loai dongho deo tay chinh hang
https://galle.vn
Deos asus motherboard model "p5nd2sli"
This motherboard only support Pentium D and Pentium 4 processor, for the complete details about it you can check this link, just click HERE.
DEO-6 top oven doesn't heat when fan oven is used
check wiring to cavity air pressure switch terminals eg the two wires should be connected to common(c) and Normally open (NO)
May 16, 2010 • Ovens
1helpful
Imy xbox 360 wireless headset deos not turn on and
Its faulty. Take it back to where you brought it from and exchange it for a new one.
If you have any problem with this start shouting very loud in the shop about how rubbish they are and how they sell faulty goods. This always works for me as they want me to go quickly and give me an exchange straight away. Hope this helps.
Problema instalar xp geforce 7050m-m
Por favor visite este sitio para instalar el controlador de tarjeta de vídeo.
http://www.nvidia.com/object/winxp_182.06_whql.html
3answers
MicroPhone Not working
Download the latest audio driver from intel site. Install it, ur mic will start working.....
Folloe the link and select Sigmatel audio driver
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2374&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#DRV
Top Atari Video Game Consoles & Games Experts
Aron
MegaByteMe
MegaByteMe
ADMIN Eric
ADMIN Eric
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
