Ilo 42" plasma tv
How do i change resolution to 1080i i have comcast digital cable box i tried to hook up a hdmi cable from box to tv and nothing....i hook everything back to componet video the way it was and tv will only stay on 720p???
  • 2 more comments
  • chris50 Dec 28, 2007
    I have the same problem. I have a 42" LCD that says its 1080/720/480 compatible and am trying to hook up the comcast HD/DVR tuner. When I hook up the HDMI cable it doesn't work. When I hook up the component cables I get the 480p to work and that's it.
  • jake1951 Apr 20, 2008
    When I hook up the Samsung 40" LCD with the HDMI cable I get nothing. When I use compnent cales it works.
  • prickypearpa Nov 28, 2008
    I am having the same issue with a Panasonic tc-26LX20 HDTV. Through component cables it works, but HDMI connection does not.
  • Anonymous Mar 11, 2009
    I have a 46" Sony Bravia and when I check the connection output it shows that I am getting a 480i output in lieu of the 1080i I should have. What is the problem?
  • 4 Answers
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Posted on Jan 12, 2008
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ... > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from
Change it: Your Comcast/Motorola HD Cable Box may be ...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
New TV is hooked up from satelite cable via HDMI wire. We have it plugged in the HDMI port # 1. When we turn on the cable, the little box pops up saying HDMI and 480P. I ready the specs for the TV and...
You have settings in your TV and satellite receiver to set the resolution for the picture. I would first go into the TV settings and use 1080p for the TV resolution. Also, in the receiver setting, you have the HDTV setting. From the main menu, press 6 (System Setup) and then 8 (HDTV Setup). For TV Type change to 1080i. The Aspect Ratio should be 16:9. I hope this helps.
Ray Calo
DISH Network
Dec 28, 2010 | Element Electronics PLX4202B 42 in. Plasma...
How can I switch my screen resolution on the Pioneer PDP-4270 from 480i to 720i or 1080i? HDMI cable is connected appropriately. I have tried new HDMI cables, and pressing reset to factory settings along...
Change the resolution on the cable box or satellite box, witch ever you have. A set by itself cannot change the resolution, if the cable is giving you 720p, that's what you'll see for that station. All stations do not transmit in HD. The best picture is only as good as they're giving you.
Dec 19, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
No dvi pictur showin up on my plasma tv
try a lower video output resolution on your PS3
Nov 09, 2009 | Gateway GTW-P42M303 42 in. Plasma...
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
I have the NS-PDP42 42" PLASMA 720-P and I would like to know how to change the screen resolution for hdmi devices. In the user guide it says to change it to 1280 x 720p but it does not tell how to...
There's no way to tell the HDMI input whether it should take 720p or 1080i input on this set. The best thing to do is experiment. Set your Comcast box to 720p and watch it that way for a while, then set it to 1080i and watch it for a while. The PDP42 has to do a little picture manipulation in either mode, but I think you'll find that the 720p mode will work best for you. I have this set with Verizon FiOS and I have the FiOS output set to 720p. Looks great, no complaints.
Jul 23, 2008 | Televison & Video
Picture shifts to left
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
Mar 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
604 people viewed this question
Top Televison & Video Experts
