When drunk I knocked the printer off the table. Now it says that the cover door for the document feeder is not closed.
Possible cause is that you have broken the DF door tail that senses the door closed. Check by opening the cover you should see a slit with either a switch in there or a light sensor. Push the switch down using small flat blade screw driver or if light sensor place a folded piece of paper in the gap.
Either one should then recognize that the door is closed.
Hope this can help and if this does work will need to replace the door.
Leading
cause of paper jams is debris/foreign objects that accidentally fell into the
paper feed area. Please follow steps below to fix the problem:
1.
Remove the sheets of paper from the feeder.
2.
Grab a flashlight and look inside the feeder for any debris or foreign objects.
3.
If you're willing and physically able, you may also turn the printer over. Any
debris should just freely roll out from the feeder.
4.
If feeder is clear, place the printer back on the table, open the printer cover
and remove the cartridges.
5.
Check the cartridge area for any obstructions/debris in the cartridge carrier's
path or the paper path.
6.
If cartridge area is clear, close the cover.
7.
Re-brick your printer. Pull out the power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
