Question about SanDisk Sansa e250 MP3 Player
Volume do not work anymore
  1. It seems to be in a freeze mode will not play any songs with or without the headphones
  • 25 Answers
You need to reset the unit. Take out the 4 screws in the backplate, and disconnect the battery. Wait about 10 seconds then reattach, and replace backplate and screws. That should do it. If not, unit is bad.
Posted on Dec 26, 2007
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Sony NWZ-E438F won't play music anymore.
there is a format problem and formatting your appartus might help you
Mar 18, 2010 | Sony NWZ-E438F Digital Media Player
Only Plays 20% of songs
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 04, 2008 | iLO (2 GB) MP3 Player
Problems with my sandisk sansa mp3
Do any of the songs play? It may be that the song(s) are corrupted. If this is the case, delete the songs and try to download them from somewhere else or, if you uploaded from a cd put them on again and see if they work. It also might be the jack that these speakers are plugged into. Sometimes the port for the speaker plug is made incorrectly, and the plug is too loose inside to actually connect, but tight enough to stay in. If it's a base cradle, does it work? Are you missing any batteries( if battery powered), or is the plug in the outlet right? Is the player connected properly? Is it actually FOR the player, or is it only for a certain type of player that you don't have? It by 'speaker' you mean headphones, the wires might be disconnected in some places. If that's the case, buy some $0.98 headphones from walmart and attempt it with those. Are the volume bars on the player and the speakers high enough up?
Jan 27, 2008 | SanDisk Sansa e260 MP3 Player
Freeze
Nov 27, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player gets stuck on first song...
Make sure the songs are in the correct format
Aug 07, 2007 | iLO (2 GB) MP3 Player
My RCA Lyra RD1072A just doesnt play songs
it freezes at the start menu just saying RCA and others times it plays a song and freezes when i turn the volume up or down can someone anyone help me please...thanx
May 16, 2007 | RCA Lyra RD1072 MP3 Player
XM 2 GO Not Playing
I had the same problem. I had to reset (use a paper clip into the RESET hole under the battery cover ( or pull out the battery for a a couple of minutes). Then, after recording some songs, I switched over MYXM and then began rotating the channel selector dial. The volume indicator arrow moved off zero and began advancing up the volume scale. I kept doing it until it about half way and my sound was back.
Nov 21, 2006 | Pioneer AirWave XM2Go Satellite Radio...
SanDisk Sansa e250 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
