Question about Dell Axim X30 Pocket PC
Power problem Only works with outside power, not with batteries even I bought a new battery. When I take it out from the cradle, everything dies. When I put it back to cradle, it has to be resetup.
  • Ktmv1 Mar 06, 2008
    Having the same problem, called Tech services in India, very helpful but looks like whole unit needs to be replaced.
    I purchased 2 new batteries still had same issues.
    Unit is 2 -3 years old with very little use, out of warranty.
    Was offered a new unit from Dell Out of Warranty Service for $229.00. Do not think I want to spend that much for out of date product.
Im having the same problem
Posted on Sep 02, 2008
Battery or the camera cradel
Parts or a new cradle are hard to find. I don't think Fuji makes them any more, although, depending on where you live, that country's distribution source may still have stock. What we sell our customers is a small charger which recharges the battery outside of the camera. They are about $10 US and plug into the USB port on any computer.
May 25, 2009 | Fuji FinePix Z3 Digital Camera
Ipaq3600 possible battery problem?
In general, Ebay Ipaq's come without a battery (well, not one worth anything). The problem is that it really could be two different issues: either the charging circuit or the battery. The only way to test this is if you know someone else that owns this model and see if the battery works in theirs, or purchase a new battery. But the new battery might not fix it, so if it's cheap, I'd try it but if you're tight on cash then it might not be worth the chance. I'd give a new battery a 70% chance of working.
Jan 18, 2009 | HP iPAQ H3600 Pocket PC
WHEN I HIT THE TALK BUTTON, IT BEGINS WITH A SCRATCHY NOISE AND SOMETMES IT SQUEELS. I HAVE UNPLUGGED EVERYTHING FOR AN HOUR OR SO AND PLUGGED EVERYTHING BACK IN. THAN AS TOLD, I TRIED TO 'REREGISTER' BOTH...
I WAS TOLD THE PROBLEM WAS PROBABLY THE BATTERY. AS THE BATTERIES ARE THREE YEARS OLD AND CONTINUE TO POWER THE UNIT I CAN'T BELIEVE IT'S THAT. IT STATES THAT THE BATTERY SHOULD LAST ONE YEAR AND WOULD INDICATE "LOW BATTERY". THE PHONES ARE ALWAYS IN THE CRADLES AND POWERED UP. I TESTED THE OUTSIDE LINE AND FOUND NO NOISE. AS THE BATTERIES ARE $20 EACH, I BOUGHT A NEW PHONE FOR $10. SINCE THEN, I HAVE RE-CONNECTED THE OLD UNIDEN PHONES, BOTH IN MY HOME OFFICE AND IN MY BEDROOM AND THEY SEEM TO WORK JUST FINE WITH A MINIMUM OF NOISE. THIS ALL OCURRED AFTER SEVERE SNOW, WIND AND RAIN STORMS.
THANKS FOR YOUR RESPONSE.
TERRY ANDERSON
Jan 16, 2009 | Uniden DECT 6.0 Cordless Telephone...
Can get it to chanrge (this is brand new)
remove the back cover and make sure the battery is inserted properly
Jan 10, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Compaq Ipaq not Charging
As I understand it, the basic cradle that comes with the Compaq Ipaq 3870 does not charge. If I were you, I'd either seek out a charging cradle or google the instructions for modifying your cradle to charge. Good luck...
Dec 02, 2008 | Compaq iPAQ H3760 Pocket PC
Mitac mio 168 non charging problem
I sent my battery back and it was replaced by the supplier. The unit is fine now so the only conclusion I can come to is that it is due to a faulty battery....
Jan 18, 2008 | Mitac Mio 168 Pocket PC
Fuji finepix f401
I had a similar issue, and also bought a new NP60 battery, to no avail. Then I dismantled the cradle, and found a fuse on the circuit board (F01 label) which showed open. I soldered a bit of 5amp fuse wire across the top of it, and everything came back to life.
DISCLAIMER - 5amp wire was the smallest I could find. I don't know what it's meant to be. I also don't know why the original fuse blew, which means that my camera probably has another fault somewhere. However, It's been working fine for over 3 months since then.
Nov 21, 2007 | Fuji FinePix F401 Digital Camera
Red Light on nothing else works
recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter to atleast 6 hrs continuously
Dec 01, 2006 | O2 Xda IIs Pocket PC
Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
Dell Axim X30 Pocket PC Logo
35 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
