Question about HP Photosmart C6180 All-In-One InkJet Printer
Can not setup wireless function on HP c6180 printer please help
  • 2 more comments
  • Anonymous Jan 07, 2008
    my computer
    my computer those not reads my printer
  • Anonymous Mar 01, 2008
    wireless cant find printer
  • HR93 Mar 09, 2008
    I got to a point in the setup where it asked me for my password from my airport base station. That password uses * and another symbol. You use the pad on the HP. It has all symbols but * & one other. I called HP one fellow said I would have to change my base station password because that symbol is not available. When I persisted and ask for a supervisor I was given another rep who said he was more knowledgeable. I forgot what he said but his answer was different from the first. I emailed HP & the rep who answered the email said that none of the symbols would work.
    Does anyone know for sure whether I can use the * symbol.
  • 3 Answers
Call 1-800 HP INVENT (1-800-474-6836)
Posted on Jan 05, 2008
2 Suggested Answers
  • 1218 Answers
SOURCE: I've been able to print from my laptop wireless to
In this situation your wireless printer might require a power reset before you print each document. Though the printing activity will take place efficiently you will have to physically go and power the printer to enable it to print. This problem might require you to reload the firmware of the router and set the wireless printer to manual IP address in order to make it work seamlessly no matter how many documents you have to print.
Posted on Nov 30, 2010
I am unable to get my photosmart premier to work on my computer..I do have the c6180 all in one printer and this is the first time I have had this problem.....what do i do??
Hi! Welcome to www.fixya.com.
Instructions
Things You'll Need Wireless network 1 Connect the power cord to your HP C6180 and press the "On" button.
2 Press the "Setup" button.
3 Press the down arrow until "Network" is highlighted, then press "OK."
4 Press the down arrow until "Wireless Setup Wizard" is highlighted, then press "OK." Your printer will search for your network.
5 Press the down arrow to display your local network, then press "OK."
Read more: How to Install C6180 Wireless ' eHow.com http://www.ehow.com/how_7291006_install-c6180-wireless.html#ixzz1SbYTznq9 Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
I've been able to print from my laptop wireless to printer HP C6180. Only lately, printer was unable to get wireless signal. My other desktop could print wireless to HP C6180. I tried uninstall driver...
Nov 30, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 fax not working. Message: Unable to send or receive faxes, press Os to continue Despite the all possible settings and driver updates, the fax has never worked. How can I fix this?
Follow the steps one by one
1. Press the Setup button - Press OK
2. Scroll to Tools - Press OK
3. Press OK on Run Fax Test
4. It will list you possible causes why you are not able to send/receive fax
If you cannot solve the issue with the Fax Report, you can do a semi-full reset on printer
( do not do the semifull reset on printer if connected to wireless, If you do so, the printer will loose wireless connectivity to router and you will have to setup the printer on router again )
Disconnect the power cord from back of printer ( when printer is powered on )
Hold the # and 6 button and while holding connect the cord back
This reset will Erase fax logs, wireless connectivity any other memory stored in printer
Follow the instructions on printer screen to re-align the printer and cartridges
Try to send/receive fax and it should work.
* Please rate this solution with Thumbs up and comment to help us improvise in providing better support
Sep 29, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 all in one will connect with my new laptop
you will need to go into the printer setup and config it for wireless printing and than go onto your network via labtop and config a network printer for use
Robb
Sep 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hello! I need help setting up my wireless network for my HP photosmart printer for a windows vista 64bit operating system. Thanks!
the first step to perform would be running wireless setup wizard on the printer.. so that it can get connected to your network. after that start the installation on the computer.
Oct 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 printer install hangs on my XP Thinkpad T43
If the installation hangs using the setup cd , the best thing that you can do here is to download the printer software from HP site and install it after that and that should correct the problem..
Sep 11, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 all-in one will not print manually from computer
The simpelest way to reconfigure you printer is to run the original CD or DVD that contained the installation software that HP gave you when you bought the All In one printer.
Simply put the CD/DVD in the computer..and if the install screen does not come up on it's own...go to the start button and select run. type in setup and click ...it should then cause the computer to go to the drive and run the program...follow instructions ...their will be a option you can select for either a USB/or printer cable connection.....BBill01
Jul 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp Photosmart C6180
In order to have a network connection you need to connect your printer to a wireless router that you have. make sure that your computer is already connected to that network.
1. Connect the printer to the router wirelessly. Press the "setup" and then press the arrow key and look for "network". Press ok when you see "network". Press the arrow key and look for wireless setup wizard. After you have successfully connect your printer to the router press ok
2. Check the ip address of the printer by printing wireless configuration page.
3.install the software for the printer
Aug 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
C6180 All-In-One InkJet... Problem
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=sg&dlc=en&product=1153494&lang=en&
download scanning software and drivers and install, print driver is not the same as scanning software/drivers
Nov 10, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
450 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
