Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi platinum plus ws-55857
Getting double image when first turning on tv. The double image is Red outline to left. Cannot adjust convergence while in this mode. After about 10 minutes it goes to normal picture. Do I need to replace the convergence amps, if so how many and what part numbers.
    Genius:
  • 1,694 Answers
Solder connects = temporary fix.......Replace IC's..best
order two STK392-570 good quality.....16 to 22.00 each
...............................T.
Posted on Dec 26, 2007
We can set the convergences great but after about 10 to 15 minutes ithe reds lines start moving a little again will not stay in position. It's a widescreen Mitsubishi rear projection tv ws-55857.
The problem - you're setting the convergence settings, but you're not saving them, you're
simply exiting the menu screen. Be sure to save your convergence setting for each
of the three colors. It sounds like you're setting RED last, and not saving its convergence setting,
whereas the GREEN & BLUE are holding their convergence settings, since you're saving them
correctly before proceeding on to RED....
Mar 15, 2011 | Mitsubishi WS-55857 55" Rear Projection...
The red and blue convergence wont set correctly how do i set them right i have red bue and green outlines in my picture on the tv
What needs to be done here is to replace the two STK-392-570 CONVERGENCE IC'S that this set uses. I have seen this in hundreds of sets just like yours.
Total parts cost will be under 25 dollars and if you buy local double that or more.
I have available for free, start to finish, step by step instructions for this repair in the set you have.
They tell you everything you will need and how to do the repair.
If this information is of interest to you rate this solution as very helpful as I do this here for free.
Also make a comment here indicating you want the instructions.
SD TECH
Sep 26, 2010 | Mitsubishi WS-55857 55" Rear Projection...
Hey I was watching my tv model number ws-55857 and my screen turned an odd blue color yet I would still be able to hear, I turned the unit off and back on and had the same issue after a few more tries it...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 24, 2010 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 turn on/auto turn off problem
After it shuts off, you need to get a code from the tv by pressing the menu and device buttons together for 5 sec. A code will flash at you made up of 2 digits. Example. 2 flashes a pause and 2 flashes points to a convergence failure. If this is not your code post yours and I will help you.
Jul 06, 2010 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Cannot adjust horizontal blue convergence on WS 55857
You still have bad grounds on the ICs. Or maybe the solder has fused another pin. If not bad grounds on the ICs you have missed them elsewhere...Really concentrate and look for these bad grounds and check your caps with a cap check. And power resistors too!!!!!
Sep 16, 2009 | Mitsubishi WS-55857 55" Rear Projection...
Replaced Convergence but pictures still display with double images
i went to converge my mitsubishi ws 73903 and the blue line wont go down to match the other ones
Oct 09, 2008 | Mitsubishi WS-73903 65" Rear Projection...
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS 55857
Hello Phyko14:
The convergence needs to be realigned, that is something that a repair center will need to do.
Aug 08, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
