Question about iRiver X20 MP3 Player
IRiver headphone jack
My iriver works fine aside from the headphones dont seem to connect properly and the sound is poor. I have tried several head phones and it is across the board, its the jack not the phones.
do i need it repaired
cheers
  • keithy47 Jan 27, 2008
    yes same problem here
    Problem Solver:
  • 16 Answers
By the sound of it, I think your headphone jack might be damaged by "tear and wear". In that case, there's little you can do aside getting it serviced. If its warranty is void or expired already, you MIGHT be able to repair it yourself, if you're handy with soldering iron (and, possibly a hot glue gun). However, that would require quite a precision work, patience and vigilance 'cause you could easily damage other electrical components, either by physical means or by burning them out with excess heat... if you're willing to risk it, that is.
To sum it up: you do need to service it.
Posted on Feb 18, 2008
IRiver E100 headphone jack
The connector is defective - probably just wear and tear
Aug 15, 2017 | iRiver E100 Digital Media Player
How can i fix the headphone jack on my iriver H10 6GB?
What i would recommend you to do is to use a different headphone jack....I am a DJ also and certain headset doesnt work properly when you have it all way..try a different one and let me know the outcome..
Thank You
Computerrep
**Please rate accordingly***
Jan 30, 2008 | iRiver H10 MP3 Player
Low and bad quality sound by headphone port
sounds like an internal problem
like a bad connection
if you have the skill, you could pull it apart and resolder the parts around the earphone output jack
hope this helps!
Jun 27, 2009 | iRiver X20 MP3 Player
One channel not working on my iRiver t10 mp3 player
Most common cause is that the solder connection that holds the headphone jack to the board is broken. Usually can be fixed by taking the player apart and re-soldering the connection. Takes some effort and a pencil type soldering iron.
The T10 headphone jack is underneath the main board and you have to undo a solder connection in order to remove the board to gain access to the headphone jack. It's a lot of work but it can be done.
Jun 08, 2008 | iRiver T10 MP3 Player
Headphone jack failure
Normal repair shop can't fix it
iRiver will not send you the headphone jacks, although you can purchase a broken iRiver on Ebay and obtain jacks for this purpose - be careful - you are risking other damage to player
You must get the entire player replaced
Sorry, but this is true of nearly all Mp3 manufacturers.
This is the only answer I can give you, because it is the only truthful answer.
Apr 18, 2008 | iRiver X20 MP3 Player
My iriver headphone jack gives distorted or no sound at all sometimes. after jiggling the phones it seems to work but it soon moves again when i move everything else works well
Have you tried using different headphones? If they work, then the headphones you currently have may have some faulty wiring. If different headphones do not work, then there may be something wrong with the headphone port on the iriver.
If there is a problem with the headphones, the best solution would just be to buy new ones. It is much less of a hassle and much less costly. If there is a problem with the iriver's port, it would be best to take it to an electronics store and have them find out exactly what is wrong.
Apr 13, 2008 | Audio Players & Recorders
My iriver X20 works fine all the features work as they should however there is a problem with the headphone jack. for some reason it does not seem to get a 'clean' connection and the sound does not come...
i am getting the exact same problem, the worst part about it is that ive had mine for just over 13 months and my warranty just ran out!!! plese tell me how long uve had urs for, i would be interested to know
Iriver iHP-140 will no longer switch on
I just reccommended a company called avsense you can find there info on the iriver website i sent mine with a wont power up and a bad headphone jack 67 dollars later its perfect again !!!! there adress is 4038clipper ct freemont ca 94538 there phone # is 1-510-445-0188
Sep 03, 2007 | iRiver iHP-120 MP3 Player
Iriver h320 dead headphone output jacks
Tried new set of head phones? My DAD fixed cars and always said to fix the cheapest part that might be haywire first.
Jul 24, 2007 | iRiver H320 MP3 Player
Cannot hear music
The bad news is that your headphone jack is most likely shot. The soldered connections inside are most likely broken. This is not repairable generally, at least not for a cost that would be reasonable. Music will play through your computer because it can be read off your player through the USB connection. Use it as a data storage drive and buy a new one, or a used one. I've seen used T30s on Amazon for around $30 to $40.
Mar 26, 2007 | iRiver T30 MP3 Player
iRiver X20 MP3 Player Logo
294 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Mohammad Abumuailek
Mohammad Abumuailek
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
