Question about Kenwood KDC-MP435U CD Player
Amps wont stay on
I installed the cd player in my 99 dodge avenger and i have an amp running to a pair of 6 by 9s and a separate amp running to subs and when im listening to the radio my amps are fine and my speakers work but whenever i use a different option of playing my music such as a cd my amps turn off and act as if they dont get any power.
  • bobw277 Dec 28, 2007
    I am having the exact same problem. I have an amp and it works fine with the radio but when I try any other option, it cuts off.
  • 68 Answers
Try to look at the connection on the back of the cd player and make sure that the amp power wire is connected to the power wire on the wire harness on the back of the cd player and that should work but i only need one amp for a pair of 6by9s and subs try to bridge the speakers all to one amp that should cause it to sta on while in cd mode hope that helps
Posted on Nov 27, 2008
I have a jvc kd r310 cd player and im running a 4 channel amp and 2 subs. How do i hook up another 4 channel amp to run my door speakers and rear speakers
There should be a "line out" on your amp. Take a pair of RCA patch cable and run it fron "line out" of the 1st amp to the "Line in" of the 2nd amp. Then wire that 4ch amp for your speakers.
May 24, 2011 | Car Audio & Video
How to wire it to make the bass cuts off when offing the eq
This unit has a separate EQ band for the subwoofer-- you'd connect the sub-out from your CD player to the sub input on the EQ, and the sub-out from the EQ into the input on the sub amp.
The "sub" slider would then adjust the sub volume.
If your CD player doesn't have a sub-out, and you are just using one of the regular front/rear outputs to feed the sub amp, then the sub volume will follow the other sliders toward the left side of the unit, which is less desirable.
Feb 13, 2011 | BOSS AUDIO SYSTEMS AVA1204 7Band Car...
I wont the speakers hooked to the cd player no the amp
check were the speakers are installed for pre existing wiring they probly left it there.. if not then you will have to run speaker wire from your stereo wiring harness to your speakers. if the speakers were hooked up to the amp then the wire in the harness should be vacant and you can use it if all the wires are connected then that means that you just have to find were that wire leads and hook your speakers up to it.
Jun 03, 2010 | Pioneer DEH-P6400 CD Player
When the radio is on the sound comes out of all the speakers. when the cd player is on the sound only comes out of the sub woofer
are you running separate amps for the woofer and speakers??? sounds like you have the woofer amp being turned on be the amp remote wire (blue/white) and the speaker amp turned on with the power antenna remote wire (blue). if this is the case you need to use the blue/white to turn both amps on.
Apr 30, 2010 | Eclipse CD2000 CD Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
I have a jvc kds580 and i wanna run a passive Bazooka EL and 4 other speakers. Can i drive the sub with the 2 RCA OUTS on the back of the unit? If not, how do i drive the sub?
RCA Outs are very low power signal connectors. They would have a hard time running a pair of headphones.
What you need is a Power Amp that the RCA's plug into and your subs Connect to.
You need an Amp (Amplifier) that powers a similar number of Watts to what your Subs Capacity is. (ie; your subs have a ratting of 100W (Watts), then you need an amplifier with 100W per channel; that's a 200W amp for a two way (Speaker) amp, or a 400W rating for an amp with 4 channels (4 Speaker connectors)
You can run a lower power amp on your subs, and use ony a portion of your speakers capacity; but if you get an amp that supplies more wattage than your speakers capacity, then you'll blow your speakers, their performance will deteriorate slowly. eventually they will not be able to generate a clear reproduction, Speakers are irrepairable.
Sorry for the long explanation.
This is something you wan't to do right, the first time.
Cheers,
Richard.
Jun 21, 2009 | JVC KD-S580 CD Player
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
1996 dodge avenger
sounds like your having a problem wiring the cd player. are you using the correct wiring harness? I just installed a cd player in my 1996 avenger and had no problems, the only thing i had a problem with was that the stock radio was malfunctioning seemed to be fixed once i installed the new cd player
Sep 25, 2008 | 1996 Dodge Avenger
How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Nov 03, 2007 | Alpine CDA-7863 CD Player
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Kenwood KDC-MP435U CD Player Logo
73 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
