Question about Fuji FinePix S3000 Digital Camera
Lens Won't Extend on Startup
Camera fires right up when you turn it on, but the lens won't extend. Image shows in viewfinder / on LCD, but it is blurry. Have tried pulling (gently and not so gently) on the lens cap upon startup, but to no avail. Camera makes brief buzzing sound (motor trying to retract already-retracted lens?) on shutdown.
Is this camera trashed?
  • Anonymous Mar 27, 2014
    I replaced the batteries on my camera and now it won't turn on. It makes a sound as if the lens is going to extend, but it stops and nothing happens.
  • Anonymous Mar 29, 2014
    It says to take the lens cap off but it is already off and we can't use the camera
  • Fuji Master
  • 4,738 Answers
Try some of the less severe repair techniques for a lens error:
Posted on Dec 26, 2007
Sanyo digital camera showing lens error 1114 or 112
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
The camera turns on then shuts back off again
hat type of problem is usually associated with a lens extend error.
It is usually caused by weak batteries or dropping the camera.
Keep your eye on the LCD screen when you turn the camera on.
Do you see any type of error message?
Now turn the camera on again and help the lens extend by gently pulling on the lens as it extends.
Does the camera stay on when you do that?
Sep 24, 2010 | Kodak EasyShare Z740 Digital Camera
Lens will not extend, screen is black, ''no image'' message
Make sure you are using a 2GB SD card or smaller. Make sure the camera is set for Camera Mode not Playback. That is the switch that shows a camera or a square with an arrow in it. When the camera is in play back the lens will not come out until the camera is set for camera mode. The no image in playback will occur every time you use an SDHC type memory card. Formatting the memory will not make the camera take the SDHC type cards since it was never designed to use them.
Nov 23, 2009 | Cameras
When turn on, lens won't extend-error message Canon SD 600 digita
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 10, 2009 | Canon PowerShot SD600 Digital Camera
Viewfinder and LED display both black.
Try pressing the power ON and when the lens has retracted, remove the batteries. Wait a few minutes. Press the power ON again. Now replace the batteries and try the camera again.
Aug 20, 2009 | Nikon COOLPIX P60 Digital Camera
Lens does not retract or show an image. D18 is shown on viewfider. everything ese works
Lens errors (believe "E18" is showing on your viewfinder) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 05, 2009 | Canon PowerShot S2 IS Digital Camera
Cannon G7 need help
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Fuji FinePix S3000 Digital Camera Logo
186 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
